Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-01-2009, 09:04 AM   #1
Default "F" type Drip edge & felt overhang
Getting ready to install roofing on new build, using "F" type vinyl drip edge on hip roof. Specs call for 3/4" overhang of DE for felt & shingles, but isn't that for "L" type drip edge? Do we just go flush to the outer edge of the DE (with felt & shingles) for the "F" type that already has an overhang "built in"?
Many Thanks
caybound is offline   Reply With Quote
Old 11-03-2009, 09:27 AM   #2
Any ideas?
Old 11-07-2009, 08:55 AM   #3
No one has used F drip edge?
Old 11-07-2009, 09:38 AM   #4
Pro Slate Roofer
Never used the F before. No matter what you're using, overhang it an inch, at least. Unless you like the water wicking under the roof.
tinner666 is offline   Reply With Quote
Old 11-07-2009, 09:42 AM   #5
Pro Slate Roofer
There is a drip edge under the slate.
Shingle without dripedge.
ID:	14676   f-type-drip-edge-felt-overhang-mvc-001f.jpg
Old 11-07-2009, 09:44 AM   #6
Pro Slate Roofer
Do note the nailing pattern on the 3-tab shingle along the rake.
More On This Topic
You can beautify the grounds of your home by building a pond and reveling in the serenity it provides. Just follow these steps. Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Now what we are going to do is under the overhang of the house we are going to delineate that with a shadow and the edge of the overhang of the house on this side and the shadow underneath this, all delineated with a shadow to give it a three dimensional... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
What happens when shingles are not started with an overhang even with drip edge ShortEdged Roofing 8 03-08-2008 02:31 AM
Vented Drip Edge? jovo14 Roofing 30 11-13-2007 08:26 AM
Drip edge mattflytx Roofing 3 09-10-2007 12:53 AM
Drip edge on a shed roof. Scott Roofing 2 10-04-2006 09:22 AM
fascia and drip edge glassman General Discussion 3 10-02-2006 08:39 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
