Exterior Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-02-2007, 03:54 PM   #1
exterior soffit
I am trying to replace old wood soffit with vinyl vented material. Guy at hardware store was helpful in putting pieces together, channel bits etc. But the soffit area is only 5 inches wide from front to back and is impossible to get a hammer in the opening to nail channel strips up.
Any suggestions as to how I can attach strips?? Don't think a nail gun or stapler will fit either.
summertime is offline   Reply With Quote
Old 10-02-2007, 04:26 PM   #2
Yes, you can probably use a small finish nailer or wide crown stapler.
They even make a palm nailer for tight fitting locations with limited access.
Ed
Ed the Roofer is offline   Reply With Quote
Old 10-06-2007, 12:30 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
actually you run a line level w/ the bottom of the fascia board on the wall,install j-channel to this line(back of j to line)nail thru back of j w/nail punch or roof nails w/ nailset tool,insert cut panels into j channel and secure to bottom of fascia board w/roof/or trim nails,then cap existing fascia board w/alum.fascia capping/wrap which you can buy at the supply house/home center-much nicer job!
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 10-06-2007, 12:32 AM   #4
you would need a compressor and air hoses to power that palm nailer ED
Old 10-06-2007, 12:47 PM   #5
He mentioned the implausibility of using a nail gun or stapler due to space considerations, so I figured he already considered the acquisition of a compressor and air hoses for this project.
Ed
Old 10-06-2007, 06:58 PM   #6
Old 10-07-2007, 01:56 AM   #7
By the way, I have never used one of those palm nailers. Only talked to one guy who did, and he said it was great.
Do you have any hands on experience with one of those?
What size nails is it capable of shooting? I would imagine you have to load one at a time.
Ed
Old 10-07-2007, 10:56 AM   #8
YES GOOD FOR ROOFING NAILS AS THE HEAD SITS AGAINST the shaft and hammers as you put pressure on it,good for closed areas where you can`t swing a hammer,otherwise it doesn`t compare,and yes you load handnails into it
Old 10-07-2007, 12:39 PM   #9
I will have to pick one of those bad boys up, since the under soffit tight areas are a regular occurrence.
Thanks.
Ed
Old 10-07-2007, 01:48 PM   #10
under soffit tight areas can easily be dealt with,w/a trim nail punch,it`s only really good where a roof tightly overshadows another,and it would be good for sheathing nails as well
