Exterior Drywall Sheathing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-10-2013, 11:19 AM   #1
I have a home built in 1945. Instead of putting wood on the outside of the studs they used 2 foot wide sections of gypsum wallboard. Covering the wallboard is cedar siding. Any tips on dealing with this situation? Thanks
JoshSEAWA is offline   Reply With Quote
Old 09-10-2013, 11:35 AM   #2
Rewards Points: 13,446
Sure it's not form of cement plaster board? Not sure why they would have use it outside unless they where planning on stucco walls, but it was common many years ago on the inside of homes.
Got a picture of it?
Old 09-10-2013, 01:00 PM   #3
No. They used the same stuff inside and out. Inside is plaster covered wallboard. The house may have been constructed during the war so materials were scarce. Anyway after 70 years it is disintegrating.
Old 09-10-2013, 01:06 PM   #4
Old 09-10-2013, 01:08 PM   #5
I don't know how to upload an image?
Old 09-10-2013, 01:10 PM   #6
Old 09-10-2013, 01:12 PM   #7
Old 09-10-2013, 01:23 PM   #8
ok I figured it out.
Old 09-10-2013, 01:36 PM   #9
A few more photos
sheathing blocks instead of h-clips, help needed roof52 Roofing/Siding 25 04-12-2012 11:38 PM
is my sheathing rotting? *pics* Nospammer Roofing/Siding 24 03-07-2012 09:06 PM
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 08:57 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
