Extending Gutter Across Side Of House Or Downspout? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-22-2013, 11:39 AM   #1
Extending gutter across side of house or downspout?
I have recently had an underground drainage system installed around my house with ground level unlets for the downspouts to divert water away from the house. I have one gutter which I haven't connected yet, mainly because it is a first floor gutter, and to reach the inlet it would have to be extended to cross an exterior wall to the corner of the house where the inlet is. My question is in two parts: Can the gutter simply be attached to siding if all it is doing is transporting water and not catching it? How would I do that so there were no leaks in the siding? And...Would it be better to just put a long downspout at an angle to the drainage inlet? Or would that cause issues with debris since it would not be straight up and down?
ddurlach is offline   Reply With Quote
Old 02-22-2013, 11:43 AM   #2
Rewards Points: 13,266
Really need a cture for any real suggestions.
Down spouts are install to the siding all the time with no issues.
Old 02-22-2013, 01:56 PM   #3
pics
I am attaching the only photo I have that fit the file size requirements. You will see the existing gutter and downspout on the first floor section. I want to extend this across the span of the entire green wall to the corner of the house. Right now the downspout is draining onto a completely irregular.
Thank you!
Old 02-22-2013, 02:20 PM   #4
Rewards Points: 12
IMO, unless it is causing water problems, I would leave the current downspout alone. You could run a gutter or angled downspout to the corner but I think it would look awful.
djlandkpl is online now   Reply With Quote
Old 02-22-2013, 02:47 PM   #5
kwikfishron's Avatar
Rewards Points: 176
You can do what you're proposing but it will always look like a mistake imo.
What you should do is pop up a few of those tiles and trench over and install a drain pipe connecting to the rest of the system.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
joecaption (02-22-2013)
Old 02-22-2013, 04:37 PM   #6
Roofmaster
Rewards Points: 2,172
Im with Kwik. Whoever installed the paver blocks should have considered the drainage coming off the roof. Aside from that, darn nice home.
The Following User Says Thank You to jagans For This Useful Post:
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 11:32 AM
Bath fan venting runs through attic and out side of house ponch37300 Kitchen & Bath Remodeling 4 09-24-2011 05:07 PM
help with cooling one side of my house. sjthompson HVAC 6 08-23-2010 05:45 PM
Gutter Downspout Question handy man88 Roofing/Siding 5 02-04-2010 09:45 AM
