Extending Gable Over Flat Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-20-2008, 09:05 PM   #1
Extending gable over flat roof?
I have a flat roof addition, same width as main structure, that projects from a gable end. It leaks. I want to extend the gable end to cover. I imagine tearing off edges of roof to expose masonry walls. Epoxy in bolts. Add sills and then frame rafters and ridge to extend existing roof line. Do I need to demo any more of the flat roof except the sill area? Do I need to demo gable end wall? Enlarge gable vents? Thanks.
PricelessDharma is offline   Reply With Quote
Old 01-20-2008, 09:14 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Pitch of new roof will determine whether you go 1' or 2' inside the wall area.
tinner666 is offline   Reply With Quote
Old 01-20-2008, 09:17 PM   #3
Pro Slate Roofer
tinner666's Avatar
On reflection, you might even be able to use a double 2x6 plate on existing so the soffits don't end up being too low. Depending on amount of overhang.
When I do these, I attempt to figure out Plan(s) A.B.C.D.E.etc, and 'go with the flow' of what I find as I get into it.
Old 01-21-2008, 01:23 AM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
-tinner
that`s about all you need to do,besides extending flues,plumbing pipes ,etc.
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-21-2008, 11:14 AM   #5
Thanks Tinner
When you said if I will be in 1' or 2' did you mean where the new rafters will cross the side walls? I am hoping that they will only hit(cross) the tops of existing stone faced block walls that are built up to the same height as the existing gabled section. What you say makes me think that building some kind o kneewall slightly inboard and parallel to the side walls across the existing flat rafters might be easier than trying to fit nice flat sills to the top of the stone. Thanks for the feedback.
Old 01-21-2008, 11:16 AM   #6
Thanks roofing God
Thanks, Luckily there are no penetrations in the flat roof.
Old 01-22-2008, 01:48 PM   #7
you`re welcome!
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 09:41 AM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
