Exposed Sheet Metal Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-28-2010, 03:49 AM   #1
Rewards Points: 200
Exposed sheet metal questions
Dear all:
Recently we had a professional roofing company replaced our roof. At the end the roofers left some bare exposed sheet metal in some areas, see these photos:
1. At the bottom of the chimney area:
2. Gutter corner/angel area:
If I understand the roofer correctly, they said that it's OK as they had never ran into trouble for doing this before and the water should NOT sip in from these two areas. However, my concern is that underneath these exposed sheet metal, it should be the plywood, so unless they did something here, otherwise the sheet metal should NOT be exposed like this. Few questions:
1. In most cases, should a roofer leave the sheet metal exposed like this? The house is located in San Francisco...
2. Would the house still be "water tight" for these two areas? IF not, what should the roofer do with these two areas (e.g. stucco over the exposed sheet metal?)... thoughts or comments about their treatment for these two areas?
Many thanks!
ohman is offline   Reply With Quote
Old 12-28-2010, 07:46 AM   #2
Rewards Points: 1,580
Looks like appropriate step flashing to me. A pro will likely offer their opinion.
bob22 is offline   Reply With Quote
Old 12-28-2010, 07:56 AM   #3
Doing This Way Too Long
Rewards Points: 532
Both pictures look neatly flashed and counterflashed with the trim and the stucco. I wouldn't have used white on the chimney or all that unpaintable silicone but installation looks good from here.
Looks like old roof was tile??
OldNBroken is offline   Reply With Quote
Old 12-28-2010, 05:56 PM   #4
Rewards Points: 150
we would remove and reinstall the gutter and trim to get the flashing under it all.
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
The Following User Says Thank You to RooferJim For This Useful Post:
Tom Struble (12-29-2010)
Old 12-29-2010, 04:11 AM   #5
Rewards Points: 200
No the old roof was tar & gravel (for the flat roof part), and shingles for the front
Old 12-29-2010, 06:29 AM   #6
Rewards Points: 85
What's with the gutters not being capped?
housegsx is offline   Reply With Quote
Old 12-31-2010, 10:46 AM   #7
Rewards Points: 200
I'm just a bit worried that the exposed sheet metal over time would develop some corrosion, and that won't be too good right? Does professionals usually just leave it like that, or there is some other ways to make it better? Thanks!
Questions on tying 6x8 exposed header to top plate EDI Remodeling 4 06-03-2010 08:27 PM
How to get sheet metal bent? darsunt Building & Construction 7 12-22-2009 12:59 PM
Best way to seal sheet metal to wood zootjeff HVAC 1 09-10-2009 07:06 AM
Transistion from Duct Board to Sheet metal zootjeff HVAC 0 06-29-2009 12:05 PM
Putting a new metal roof on got i got questions aokss Roofing/Siding 9 06-10-2006 12:06 AM
