#1 |
exhaust venting
The remodel will include something we haven't had- a range hood. When I had the roof replaced 4 years ago I asked for a vent to be installed so we would be ready for the range hood. I didn't really think about it at the time, but now I have questions.
The vent is a 6" duct and the cap is only a few inches off the roof deck. The gap from the cap to the deck is only a 3 inches, +/- . Is this too close to the deck? The range hood has a 7" round option(vertical), or a 3.25" x 10" rect. option. I can use either, is one better than the other? Will there be much problem reducing the 7" hood duct to match the 6" exhaust cap? Or should I get some pricing on enlarging the exhaust duct? BTW, the roof is a torch down membrane. Pitch might be about 3 in 12. Thanks! |
#2 |
Moderator
exhaust venting
I'd check with the hood manufacturer before reducing. The round is better. 3.25x10 = 32.25 7x 3.1416 = 21.99 or 10+ smaller, yet manu. says either. The round is 33% less surface area for grease to accumulate on and easier to work with. Three sheet metal screws at each joint, try to use 45* elbows instead of 90*. Tape all joints and elbow joints with foil tape, and support duct work securely. I'd pay a roofer to install the correct terminal cap:
http://www.lowes.com/lowes/lkn?actio...1CM&lpage=none Check with him if proper one. Be safe, G Last edited by Gary in WA; 07-22-2009 at 09:45 PM. |
#3 |
exhaust venting
Thanks for the comments, I may talk to a couple of roof guys and see what sort of money they want to do this job.
Can someone point me to examples of, or instructions to, properly flashed roof exhaust caps used with torch down roof membrane? |
| Display Modes | |
| Venting | ponch37300 | Plumbing | 41 | 02-23-2013 11:37 PM |
| Soffit venting vs. DCI Smart Vent | JDPII | Roofing/Siding | 1 | 02-28-2009 09:42 PM |
| Can I T my new dryer's exhaust into my bathrooms exhaust? | Felipon | Appliances | 2 | 01-30-2008 07:53 PM |
| Complex challenge with bath exhaust fan - need help with solution! | Honest Bill | Electrical | 6 | 11-02-2007 03:52 PM |
| Furnace Exhaust To Outdoors | celticFC | HVAC | 1 | 09-01-2007 02:27 PM |
