#1 |
Exhaust vent on roof
I have a dryer exhaust vent on the roof that I will probably have replaced.
Is it true that the way these are generally installed, the tech will not need to access the attic, as there is a connector/interface piece that is installed onto the roof sheathing from the outside, and then the exhaust vent is installed on top of this under the shingles? |
#2 |
Commercial Roofing
Give us a picture and we will let you know.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Free inspection within 12 miles Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN! |
| Display Modes | |
| Roof Vent Height | Klawman | HVAC | 46 | 03-11-2010 10:56 PM |
| Remove Pipe Vent from Asphalt Shingle Roof | WaldenL | Roofing/Siding | 5 | 09-26-2009 02:46 PM |
| Vent dryer through flat membrane roof | Vince Rosati | General Discussion | 6 | 11-02-2008 03:11 PM |
| hip roof vent | pinkertonpv | Roofing/Siding | 10 | 10-07-2008 07:58 PM |
| is an attic vent required for cedar shingle roof? | walenta | Building & Construction | 2 | 10-25-2007 11:31 AM |
