Excessive HEAT In Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-24-2013, 10:22 PM   #16
Registered User
Rewards Points: 4,890
You are in Zone 4; http://publicecodes.cyberregs.com/ic..._11_par002.htm
Code requires R-30 ceiling: http://publicecodes.cyberregs.com/ic..._11_sec002.htm
Do you have a full attic or knee-wall and top attic with cathedral (sloped) ceilings;pp. 10, 11; http://www.awc.org/pdf/WCD1-300.pdf
Attic air sealing; first, insulation; second, ventilation; third.
How to post a picture, first group on the list; http://www.diychatroom.com/f98/
or describe the attic/rafters better.
Gary
Old 05-25-2013, 12:12 AM   #17
Lord of Slums
Rewards Points: 1,974
What are these baffles before foam insulation underside of roof. Where do you look for air leaks?
mj12 is offline   Reply With Quote
Old 05-25-2013, 02:16 AM   #18
Rewards Points: 6,652
For air leaks, anywhere that you have a access hatch, whole house fan, wires entering the attic through the walls, pipes, chimney's, etc.. As for the baffles, they are foam, and placed at the edge, where roof meets ceiling of the living space, so that even if you do not have soffit's in your home, it allows air to come up through into the attic, for better ventilation.
Old 05-25-2013, 08:55 AM   #19
Rewards Points: 4,780
Baffles normally allow a channel of air kept open down to the soffit vents, so they don't get covered by insulation. But when the underside of your roof is coated with foam, they serve another purpose - to keep a cushion of air to buffer the shingles from overheating. If the sun beats on your shingles and the heat is trapped, it can cause premature wearing of your shingles.
jeffnc is offline   Reply With Quote
Old 05-25-2013, 09:46 PM   #20
Rewards Points: 626
were I live foam sprayed on the sheathing of a roof in the attic is a major code violation. Not alowwed to do it will cause very premature roof failur at best.
Nailbags is offline   Reply With Quote
Old 05-25-2013, 10:55 PM   #21
Registered User
Where are you located, Nailbags?
mj12, are these rafters with drywall attached or open attic; insulation on ceiling joists/floor?
Gary
Old 05-25-2013, 11:00 PM   #22
Very premature roof failure at best. Hmmm. I shudder to think what might happen at worst. Immediate explosion of the premises?
And you live in Pacific Northwest, where it isn't hot.
Sounds rather exaggerated to me. It shouldn't be a code violation at all if baffles are in place. And if they're not - then code violation or no, there's certainly nothing worse going to happen where you live than in more difficult climates.
Old 05-26-2013, 02:23 PM   #23
Rewards Points: 2,630
Originally Posted by jeffnc View Post
Soffit vents alone don't do any good.
Exactly. Ambient air enters the soffit vent, and exits at the top of the roof. With only an air inlet and no air exit, you don't have any ventilation for your attic. Sounds like you already have one quote for adding roof vents. Call at least one other roofer, and just say "I am not sure if I have sufficient attic ventilation". You may find different roofers have somewhat different opinions on how best to ventilate the attic (i.e ridge vent, whirly-birds, etc). I am figuring the salesman should be asking to go up into your attic to check that the soffit vents are not plugged (its too common that people insulate their attics and stuff insulation over top of the soffit vents).
SPS-1 is offline   Reply With Quote
Old 05-26-2013, 02:32 PM   #24
Correct, should be applied to the ceiling area of the living space, if the attic is not going to be used as living or finished space for storage. Otherwise, you apply per directions at http://www.icynene.com/
Remember, it is the heat from underneath that causes breakdown, along with if you do not have shade above, beating sun will cause breakdown. We also discussed the subject of Spray foam for attics, back in 2008 Air cavity required behind spray foam roof insulation
Old 05-26-2013, 07:13 PM   #25
Registered User
Insulating the attic from conditioned space will work the best; R-38 is required per code for your Zone4;http://publicecodes.cyberregs.com/ic..._11_sec002.htm
This will stop/slow 98% of the heat flux; http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
Radiant/with venting stops/slows 28%; http://www.rfoil.com/pdf/8-Effect-of...erformance.pdf
I would air-seal the attic first, add code minimum insulation R-value; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Ventilate the attic better if showing signs of excessive heat/moisture in attic framing/on shingles. http://www.professionalroofing.net/a...2/feature2.asp
At least to code (minimum); http://publicecodes.cyberregs.com/ic...9_8_sec006.htm
Use a fan only if the air path from soffit/ridge is restricted (hips/valleys/dormers/etc.) http://www.greenbuildingadvisor.com/...tilators-green
Is any HVAC duct/unit in attic?
Gary
Old 05-26-2013, 08:20 PM   #26
Dave Sal's Avatar
Rewards Points: 566
I had a similar problem a long time ago. The upper attic (tri-level home) would get extremely hot during the summer. I added extra insulation which helped quite a bit but I needed to do more. Extra soffit vents helped again, but since my roof shingles are brown the sun really heats them up. I decided to install a power attic vent and have been monitoring the attic temps with a remote thermometer sensor. On hot, sunny days it used to get above 125 routinely. Now with the addition of the power attic vent it stays around 105-107 at the highest. The only issue I had was when a raccoon decided to climb into the attic through the power attic vent. It tore off the screening around the edge and then bent one of the fan blades and jumped down into the attic. In the first pic you can see one of the fan blades bent down. I could hear it walking around up there one night so I went to my local police department animal control office and borrowed a trap. Baited it and stuck it up there but never caught it. I was lucky in that I placed it directly underneath the attic fan and it used the trap as a sort of ladder and apparently climbed out on it's own. After that I bought some heavy gauge mesh and secured it to the underside of the fan opening. Nothing is getting through that. (knocks wood).
Excessive HEAT in Attic-attic-fan-1.jpg   Excessive HEAT in Attic-img_1859.jpg
Dave Sal is offline   Reply With Quote
Old 05-27-2013, 09:43 AM   #27
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 824
If you are not going to treat the attic as conditioned space, there is zero reason to insulated the roof deck.
Get the venting figured out and if you have soffits (albeit unclogged or obstructed) vents, a proper soffit-ridge combination will work perfectly when done right.
Old 05-27-2013, 03:27 PM   #28
Lord of Slums
I have seen guys take 2 inch foam board and attach it flush with the bottom of the attic rafters. They leave an 1/4 inch gap on each side and then spray foam everything together. I guess that is the same as installing baffles and spray foaming the ceiling. Would you also use baffles on a south facing wall if it was going to get spray foamed as well?
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat Loss through attic to Roof on top of Shower, Please Help yogi29m Building & Construction 0 02-05-2013 04:55 PM
why the Heat Pump - Attic Unit Vibrate? DaveA HVAC 1 01-27-2011 11:29 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
hot water heat attic central air...hot basement in summer spttrac214 HVAC 2 02-29-2008 06:24 AM
