Exact Waste Factor On Paper - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-09-2010, 03:32 PM   #1
Post
Exact waste factor on paper
I am used to 10% waste on gable roofs and 15+% on hip roofs, but what I am looking to figure out is a real life formula. Is it possible to take all of our data collected, such as perimeter, ridge, valley, and concise measurements, to come up with an exact waste factor on paper. It may not always work out that way of course, but I want a justifiable waste factor. I would imagine we could take math and figure out how much waste we are using on the perimeters. Such as if there is 450lf of perimeter, how many shingles will have to be cut. How many will still usable for another end shingle? How about the same theory with valleys? I know technique comes into this. For example, we use starter strips instead of 3 tab. We use the "California Cut" instead of weaved valleys. How about waste by the ridge, whether or not there is ridge vent installed. There are a million variables, but can anyone give their insight on some mathematical ways of figuring this out? Thanks and this is a great site! I'm glad I found it.
Justen is offline   Reply With Quote
Old 04-09-2010, 06:00 PM   #2
Residential Roofer
Slyfox's Avatar
Your question sounds more like your a roofer than a diy'r,
there is a sister forum for contractors to use Contractor Talk.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-10-2010, 09:53 AM   #3
jlhaslip's Avatar
Rewards Points: 2,748
There is never any waste on my jobs.
We roll up our cigarettes with the stuff we cut off. Doubles the tar intake. Cheaper than smokes...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-10-2010, 04:54 PM   #4
Originally Posted by Justen View Post
. . .if there is 450lf of perimeter, how many shingles will have to be cut.
If I correctly understand your question this may take some back and forth, and maybe a small computer program.
In the simple and unrealistic case of one layer of non-overlapping shingles:
for a square shape
with 450 lf perimeter
the area is (450/4)^2 = 12656.25 sf.
This will take 4218.75 shingles of dimension 1' x 3'.
For a rectangle shape of 1:3 ratio
the area is 9492.1875 sf
and will take 3164.0625 shingles.
How much shingle overlap?
What other complicating factors are there?
Let's work out one case at a time.
Tags
factor , ridge , roof , valley , waste
To remove or not to remove tar paper, that is the question Jeremy Hillary Boob, PhD Building & Construction 4 02-27-2011 08:34 PM
Help -Tar Paper on basement walls atm Building & Construction 9 09-28-2009 11:41 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 03:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 07:57 AM
