Epdm Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-19-2011, 05:29 PM   #1
epdm roofing
how mutch does it cost to take out a30000,o sq ft roof with big size stone on top,and re roof with .45 ml epdm .
samcoq is offline   Reply With Quote
Old 06-19-2011, 07:47 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
No idea since nobody would spec .045 for a ballasted roof. The .045 is great for covering things in your yard, or on the job though.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
seeyou (06-20-2011)
Old 07-06-2011, 11:38 AM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Well I do agree with Tinner, though I have repaired and restored numerous 45 mil ballasted roofs. It's a 10 year rated roof and a ridiculous investment, but they are out there.
So your question of how much it should cost can not be answered. There is nowhere near enough detail. How is the access to the building? can it be vacuumed off or does it need to be manuallyr emoved? How tall is the building? What kind of insulation do you want? Material and labor prices vary regionally. How do you want the new EPDM installed (mechanically attached or fully adhered or ballasted?) So many flat roofing options so little time.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 08-15-2011, 08:04 AM   #4
bright-roof's Avatar
Agree with Grumpy
bright-roof is offline   Reply With Quote
EPDM Roofing For Camper and Building BigJim Roofing/Siding 5 04-19-2011 10:06 PM
Tying in Torch down Roofing to EPDM Sherryfr Roofing/Siding 6 04-06-2011 09:14 PM
EPDM Rubber Membrane Roofing Q's flatlander745 Roofing/Siding 1 04-01-2011 06:44 PM
Advice about EPDM roofing skiposwald Roofing/Siding 6 11-02-2010 10:56 AM
EPDM roofing questions zantar Roofing/Siding 4 05-03-2009 07:10 PM
