EPDM Roof Repairing Protrusion Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-04-2007, 12:05 AM   #1
With an EPDM rubber roof, how does one repair a leak in a protrusion area? For example, when there is a leak around a propane water heater chimney's boot, or if the boot/flashing needs to be replaced?
thanks for any advice, this forum is great!
Basic_Homeowner is offline   Reply With Quote
Old 06-04-2007, 02:22 PM   #2
Rewards Points: 150
Foe an emergency temp repair you can caulk it with clear silicone, permanent repair has to be done by a roofer who does EPDM roofs . "do not use tar or tar like product no matter what."
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Old 06-05-2007, 11:38 PM   #3
What types of roofing materials (for low sloped roofs) can a homeowner maintain and repair themselves?
Old 06-06-2007, 04:45 PM   #4
Commercial Roofing
AaronB's Avatar
RooferJim
Roger that.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
garage roof leak Chicago Bill Roofing/Siding 8 05-05-2009 01:07 PM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 10:27 PM
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 10:03 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
