EPDM Roof Plans - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-27-2010, 03:34 PM   #31
Commercial Roofing
AaronB's Avatar
So you are spfoaming the underside of the roof deck in order not to vent the cavity between the ceiling and roof deck? That is not the purpose of unvented space.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-27-2010, 03:38 PM   #32
We are sprayfoaming the underside of the roof deck for two reasons,
1) To achieve the minimum required r value as established by code
2) To do away with the need of venting as it would be cumbersome and would interfere with the ability to properly insulate the structure.
This process is allowed by code here in DC and is done somewhat regularly. An explanation of the process can be found here.
stubits is offline   Reply With Quote
Old 04-27-2010, 03:39 PM   #33
Commercial Roofing
AaronB's Avatar
SO then there will be no insulation on the ceiling?
I am aware of the practice.
Old 04-27-2010, 03:41 PM   #34
The drywall will be attached directly to the roof rafter, there will be no ceiling joists. The entire space between the drywall and the roof deck(7.5") will be filled with sprayfoam.
If there's something off about it, it would be good to know, but my architect is pretty certain about it, as are some of the local contracts I have contacted. Also, the material in the link I shared makes sense and seems authoritative. Perhaps I am explaining things wrong, but if this is horribly wrong, I'd like to figure it out.
Thanks!!
Old 04-27-2010, 08:54 PM   #35
Commercial Roofing
AaronB's Avatar
Nope, all good.
Old 04-28-2010, 03:45 PM   #36
Thanks Aaron, sorry I wasn't explaining things so well!
So, can anyone help me to understand the method for "box folding" indicated by Frank? Does anyone have any photos of this practice?
Old 04-28-2010, 05:33 PM   #37
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Here it come. I took a flat piece of cardboard and bent it into the shape of a step-flashing.
Then I box folded it, kinda step by step. The angle depends on how your corner pitches meet each other.
The last step is to seal the inside of the fold to prevent moisture from getting into the crease and freezing in the winter.
I left one other optional step out. If it tries to unfold any, or you just want to really seal it off, fold the top onto itself to clamp it closed.
EPDM Roof Plans-box-folding-flashing-2-.jpg   EPDM Roof Plans-box-folding-flashing-3-.jpg   EPDM Roof Plans-box-folding-flashing-4-.jpg   EPDM Roof Plans-box-folding-flashing-5-.jpg   EPDM Roof Plans-box-folding-flashing-6-.jpg
tinner666 is offline   Reply With Quote
Old 04-28-2010, 05:39 PM   #38
Pro Slate Roofer
tinner666's Avatar
I jusr remembered I have examples on my website on this page too.
http://www.albertsroofing.com/Metal%...%20Details.htm
There are other helpful details on my site too. Feel free to browse http://www.albertsroofing.com/index.htm
Old 04-28-2010, 10:00 PM   #39
Commercial Roofing
AaronB's Avatar
The corner worries me, Frank.
Old 04-29-2010, 04:04 AM   #40
First of all, Frank, wow! Talk about above and beyond. Your pictures were perfect and extremely helpful. Thanks!
Aaron, what are your concerns exactly? Is there a better way to handle this corner in your opinion? Or is your concern about my attempting that corner DIY?
One thought, can I bring the dimensions to a sheet metal shop and have them design something?
Thanks guys, for everything!
Old 04-29-2010, 05:23 AM   #41
Pro Slate Roofer
tinner666's Avatar
I'm sure it's the rookie factor. Corners are critical and it's easy to build a leak into the roof.
It will need to be folded to fit, on site. It's almost how you would need to bend EPDM to close it's corner. Only difference is that with EPDM, all the sides would need priming, then, each detail of the fold would need to be glued seperately because it is a contact glue, and the fold would finish on the roof side, not out of site.
Thing is, flashings are never cut in critical areas. Unless you want to use copper and solder to fit. That requires another skill and mindset to do it correctly.
Here's an EPDM corner that looks like crap, but is serviceable. It's not glued because there was no room to work. Less than 2" above the roof deck, and 5" under an overhang with a valley dumping water there too. It should give you an idea.
We roofers prefer not to show our ugly solutions! When I do the upper roof this fall, I will make it prettier and even less visible.
Old 04-29-2010, 05:26 AM   #42
Pro Slate Roofer
tinner666's Avatar
I'll have limited to no internet this weekend, so you might need to call me if you can't wait for certain answers.
Old 04-29-2010, 04:10 PM   #43
Commercial Roofing
AaronB's Avatar
The thing that worries me is the very point of the fold fatiguing and cracking open.
Old 04-29-2010, 06:58 PM   #44
Pro Slate Roofer
tinner666's Avatar
A good point Aaron. These are confined to small pieces of step and corners, usually 8" long, 4" wide, 4" tall and I've never even seen an old one that failed. The only failures I've observed was when the applicator turned the fold the wrong way and lots of water was directed into the dwelling behind corners like 1/2 chimneys. And stubits, take note! If at first you bend it wrong, toss it! Do another. Metal can safely fold once. Not twice. Then, you WILL fatigue it.
In your case, the wall counter-flashing will hide the corner itself, the the termination flashing will hide (cover) it again. Any flexible sealant should be fine. Or, like I noted before, it can be folded shut on the top.
Old 04-30-2010, 11:06 PM   #45
Inside corners on EPDM are easy. Just cut a 12x12 inch piece of flashing, remembering to round your corners. Fold the entire piece in half. Take the remaining half and fold it again in the other direction, but only half way this time so that it looks like an "L". Take the corner of that "L" and shove it into the corner. Worth the inside transition in, and then the two faces of the "L". Now on the other side, slowly unfold the rest of your membrane on the opposing wall. They should meet at the corner. forming a "pig ear". Often times manufacturers want you to place a patch over the "pig ear" as well.
Don't worry about the fold cracking. That is the standard spec for EPDM. If you really are worried about it, put a patch on top of the fold.
FIRESTONE DETAIL: http://www.firestonesp.com/bmt/files...n%20Detail.pdf
I've done countless single ply roofs for commercial contractors. If you have a question feel free to ask.
edit: I just read the 2nd page and realized you are going with shingles instead and are talking about putting a corner on your tin shingles. ignore everything i said..
chimx is offline   Reply With Quote
Flat Roof - EPDM sealant kayakertom Roofing/Siding 0 03-19-2010 04:19 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 10:03 PM
