EPDM Roof Patch - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-11-2010, 12:46 PM   #1
EPDM Roof Patch
I recently got a roof patch to fix a leak. After a few rain storms we discovered that the roof was still leaking. We eventually got another roofing contractor to check it out. He has alot more experience in the business than the one that did the patch. When he pulled up the patch to replace the whole roof, he saw that the old damaged section of the original roof was still there, and soaking wet. He told us that to properly do a patch, the original damaged part needs to be removed, especially if it is soaked. Is this the case? Did the patch get installed correctly?
antelope420 is offline   Reply With Quote
Old 05-11-2010, 09:20 PM   #2
Commercial Roofing
AaronB's Avatar
To accurately answer this, we would need to know how it was repaired. If it was soaking wet, then it most likely wasn't done correctly, but that happens a lot with under-qualified personnel.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
EPDM Roof Plans stubits Roofing/Siding 44 05-01-2010 12:06 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
EPDM roofing questions zantar Roofing/Siding 4 05-03-2009 08:10 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 07:03 AM
