EPDM Roof At Door Sill. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2013, 09:05 PM   #1
Rewards Points: 131
EPDM Roof at door sill.
I have a deck over my attached garage. There is a sliding door leading out to the deck. Currently, there is a corrugated metal roof over the garage with a floating treated wood deck. I had a water leak by the door that I fixed with tar albeit temporary. I now have a new leak. I think it is best to replace the roof. I have worked with epdm before and the roof is small enough that I would not have any joints. At the sliding door, there is only about 1-2 inches of height between the roof and the door. So, how could I get a proper seal? If it involves removing the sliding door to install the membrane on the sill and finishing the inside corners of the door frame with epdm corners, how difficult is it to remove and reinstall a sliding door? Or, possibly with French doors?
Thanks,
Mark
wwkayaker is offline   Reply With Quote
Old 04-29-2013, 08:15 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 834
Not terribly difficult.
If you are re-doing that roof, you probably have all the skills that it would take to hang a door.
Old 04-29-2013, 10:26 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
A.- No biggie. Pull the door and install a 'cut-to fit' 2x and run the EPDM up it like the wall is done.
B.- Alternatively, pull the door and install a sill pan under and around it. Run the EPDM into and up the pan. It can still overflow in heavy rain though.
C.- Do B., then install a 'cut-to fit' 2x and run the EPDM up it like the wall is done too.
NO PENETRATIONS allowed in sill pan areas! Glue, or free float only.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Windows on Wash (04-29-2013)
Old 04-29-2013, 10:57 PM   #4
Rewards Points: 131
Thanks. I was thinking about replacing the door as well so I guess now is the time.
Ponding on EPDM roof MLyle Roofing/Siding 15 03-10-2012 09:18 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Ceiling water damage below flat roof with EPDM gofurther Roofing/Siding 11 03-23-2009 12:27 PM
EPDM vs Modified Bitumen for flat roof arubatan Roofing/Siding 16 11-19-2008 07:50 AM
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 11:03 PM
