Epdm Fully Adhered To Tall Walls - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-29-2009, 10:30 AM   #1
epdm fully adhered to tall walls
i need help on installing epdm on tall walls how big should the peices be what is easy way to install
colemanco1 is offline   Reply With Quote
Old 01-29-2009, 11:57 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
sounds interesting what are you doing? any pics?
Tom Struble is offline   Reply With Quote
Old 01-29-2009, 12:18 PM   #3
Grumpy's Avatar
Rewards Points: 508
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
The tallest wall I have done was 4'. We wrapped it up and over the top and secured with mechanical means, using a metal coping. We got lucky, the wall was plywood, however the same methods would be the same on masonry. We did this in one piece. A good resource for the installation fo epdm is Firestone's website at www.firestonebpco.com you can spend about $40 and buy their installation tapes or just hire a professional roofer.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is online now   Reply With Quote
Old 01-31-2009, 04:48 AM   #4
epdm has fair longevity, weatherability, flexibilty and resistance to different rays. This link can help you in Liquid Roof or epdm Application.
angel2008 is offline   Reply With Quote
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 10:48 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 09:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
