Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-08-2009, 06:53 PM   #1
epdm and drip edge
Hello all , I have recently built a bedroom addition onto my house. I used epdm rubber roofing and i want to use drip edge instead of termination bars. So my question is how can i fasten the drip edge to the rubber without screwing it down or puncturing the top? I dont want to have to worry about leaks coming from the screws. Is there a glue that i can use for this ? Thx for any help.
devilleather is offline   Reply With Quote
Old 11-08-2009, 07:07 PM   #2
epdm and drip edge
check with the EPDM manufacturer. they should have a recommended adhesive and sealant.
cellophane is offline   Reply With Quote
Old 11-08-2009, 07:18 PM   #3
epdm and drip edge
Well i still have plenty of the glue i used for the rubber but am unsure if it will bond metal to rubber. thx for your reply
Old 11-08-2009, 08:30 PM   #4
Pro Slate Roofer
tinner666's Avatar
epdm and drip edge
Forget DE. You need commercial .032 metal. Must be primed, then self adhered cover tape (RM) goes on next.
Frank
tinner666 is offline   Reply With Quote
Old 11-08-2009, 09:41 PM   #5
epdm and drip edge
First off, thx for your helpful reply. A few questions
1.Can I get this metal and tape at my local lumber store or home depot or is it special order?
2.Does it have a 90 angle that goes down the facia board so i can slide the guttering underneath?
Again thx for your help
Old 11-08-2009, 10:44 PM   #6
Pro Slate Roofer
tinner666's Avatar
epdm and drip edge
Yes, you can buy the metal bent that way. Roofing supply house have it.
I don't know where to get the RM, primer, or the cleaner needed, other than a roofing supply house. Never looked into HD, Lowes, Hardware, or elsewhere. Sorry.
Frank
anchoring aluminum railing through EPDM roof? jbluth Roofing 1 09-12-2009 06:34 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing 11 01-07-2008 09:41 AM
