Enough Ventilation? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2012, 05:37 PM   #16
Canned lights
I hope that it helps that they are IC energy effecient air lock type. Plus they are never on anyway.
Mikegp12 is offline   Reply With Quote
Old 07-07-2012, 09:32 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 836
Being airtight does help considerably as well as not being on and hot.
The nagging issue in these cases is the lack or R-Value at those locations because of the reduced depths of insulation.
The air loss is the biggest issues and that is handled by the airtight can if installed properly (that is always questionable) so you are ahead of the game in that case.
Most vaulted ceilings are seriously lacking in both venting and insulation depth so I would plan on always having some melting issues on that roof until you rip it off and spray foam the whole thing.
Old 07-07-2012, 12:32 PM   #18
Ventilation
I hope builders and buyers learn more about these problems. I admit I knew nothing about attic venting until I started looking to replace the roof due to hail damage.. And evidently the builder, roofer, insulator,sider, architect and inspectors either didn't care or didn't know to do this right when the house was built in 2004.
I can't justify tearing everything off and starting over because my heating and cooling bills are very reasonable and there are no signs of moisture problems.
I have one area of ice damming that I will install heating cable as a easy if not perfect fix. Oddly, the only ice dam area is where there is NO overhang.
Thanks to all for your valuable information.
Mike
Old 07-07-2012, 08:50 PM   #19
Registered User
Rewards Points: 4,894
That ice dam isn't near a bath fan roof termination is it? Or a plumbing stack vent....
That said, I'll leave you with some light reading; http://www.jlconline.com/cgi-local/v...170a32100a05c7
http://www.professionalroofing.net/a...2/feature2.asp
Keep an eye on any signs of moisture on roof sheathing, etc; http://www.buildingscience.com/docum...bout-diffusion
Gary
Old 07-08-2012, 08:24 PM   #20
light reading
Thanks GBR. That was a very interesting article at www.jlconline.com. Makes me feel a little better about my situation.
Is there a way air seal ceiling fan boxes from inside the house ??
Thanks,
Mike
Old 07-13-2012, 12:30 AM   #21
Registered User
You could caulk/foam around them, and foil tape inside on the extra holes to the attic.
Gary
Old 07-13-2012, 02:00 PM   #22
another question and picture
I have attached a picture taken from the attic above the garage. You can see there is a triangular section of plywood sheathing at the peak of where the garage meets the house attic. It seems like this would really impair air movement between these areas. Can any expert framers tell me if this is structural or there for a reason.
Old 07-14-2012, 11:37 AM   #23
Rewards Points: 836
Don't cut that out.
It is bracing and stabilizing the top chords of those trusses.
You could just cut some small circular vents in spaces between the trusses and you will not weaken that bracing at all.
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 12:19 PM
Proper Balanced Ventilation? echase Roofing/Siding 8 04-21-2010 05:44 PM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 12:10 PM
