Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-25-2010, 12:19 PM   #1
End of roof too short
I have a workshop with a dutch style roof. The top point is fine, but the bottom edge was cut next to the wall. Is there a good way to keep water from leaking where the end of the roof is cut next to the wall? I thought of trying to slide metal flashing up unter the roofing tiles and let it hang down over the seam. Would that work? The roof leaks only at the bottom four corners where the roof is short. I have already tried to seal the corners with silacone. It still leaks.
robyelsa is offline   Reply With Quote
Old 09-26-2010, 01:54 AM   #2
pics would help
federer is offline   Reply With Quote
Old 09-27-2010, 10:16 AM   #3
I can't figure out how to insert photos to this site. Let me look around for directions and get back to you.
Old 09-27-2010, 11:00 AM   #4
Residential Roofer
Slyfox's Avatar
I believe there's a minimum posting requirement.
Once you have enough post it's simply a matter of clicking on the 'Insert Image' button above.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 09-27-2010, 12:29 PM   #5
i believe i posted pics on my first post
EPDM - flat roof to sloped roof transition emtaboy Roofing 12 07-14-2010 01:12 AM
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing 7 04-22-2010 09:32 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing 5 01-06-2009 07:51 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Short ladder on roof? firsthomegal Painting 6 06-17-2007 10:30 PM
