Enclosing Downspout Pipe - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-16-2014, 12:33 PM   #1
Rewards Points: 24
Question
Enclosing downspout pipe
Hi there,
Hoping this is the right section for this question...
I'm planning to re-route the downspout from my eavesthrough so that it drains out into the garden vs. down into the house (see picture attached).
I'm wondering what's the best way to cap off the pipe. It's right up against the brick of my house, so it's not easy to get a plastic cap or anything around it.
Any and all advice would be appreciated. Thanks,
H
handeman is offline   Reply With Quote
Old 08-16-2014, 01:17 PM   #2
Rewards Points: 612
Looks like it's half filled with concrete already, might as well finish it off the same way.
Cut the pipe above the hole, fold it out to give the concrete some backer. I do this pretty regularly, it's simpler then it sounds.
PatChap is offline   Reply With Quote
Old 08-17-2014, 10:39 AM   #3
Rewards Points: 166
if it were me, i wouldn't do anything permanent. you never know if you ever need to use that again. if it were me, i would get a rock or brick to just set on there.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
roofermann (08-17-2014)
Tags
downspout , drain , eavestrough , gutter , pipe
Eaves trough downspout drainage issue between neighbors frankm1960 Landscaping & Lawn Care 20 07-19-2014 09:31 PM
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 09:59 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 01:49 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
