Enclosed Entryway Is Leaking How To Seal? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-16-2016, 09:06 AM   #1
Rewards Points: 174
Enclosed entryway is leaking how to seal?
I have a closed entry over a brick floor. We noticed that when it rains that it leaks inside. I don't think they sealed the wood to the bricks. I know I will need to check for mold because I think it has been like this for 20 years. However I want to seal it before winter to help keep our house warmer. What can i use to seal it? I put duct tape there for now. Sorry that the pictures are upside down. Thanks for advice.
Enclosed entryway is leaking how to seal?-1474034591342.jpg   Enclosed entryway is leaking how to seal?-1474034621922.jpg
jwiens is online now   Reply With Quote
Old 09-16-2016, 09:20 AM   #2
Rewards Points: 174
Re: Enclosed entryway is leaking how to seal?
I live in NM in the mountains so we get a decent amount of snow, but it isn't humid typically. Here is a shot of the inside. Last winter I put curtains up in between this room and the house and this room would be incredibly cold.
Enclosed entryway is leaking how to seal?-1474035519683.jpg   Enclosed entryway is leaking how to seal?-1474035621096.jpg
Old 09-16-2016, 03:01 PM   #3
DIY staff
Rewards Points: 7,174
I hate to be the bearer of bad new--that (most likely) was built without water proofing and is missing a Z-flashing at the bottom to direct the water from behind the exterior wood ,out beyond the brick.
The right solution will be to remover the exterior siding--add Tyvek house wrap or tat paper--with a metal z molding at the bottom to direct water to the outside of the brick.
Also--removing the sheeting behind the siding might be wise--I bet that the insulation is missing or under sized--
Old 09-16-2016, 03:09 PM   #4
Rewards Points: 174
I was thinking I might be in trouble. Is there a temporary fix I can calk or something like that? I'm in the middle of a kitchen and bath remodel so i pretty much want to just patch it up for this winter and then redo it next summer.
Old 09-16-2016, 03:33 PM   #5
DIY staff
Water is getting behind the siding---and also hitting the brick and working its way under the wall---
Caulk the wall joints--and the siding/ brick connection---that might help although the siding / brick connection might keep the wall from draining out---your call---it was a bad original design---the maker forgot that water gets behind siding--
Old 09-16-2016, 05:35 PM   #6
Rewards Points: 14,312
Sorry, have to agree, looks like someone tried to use duct tape instead of the proper flashing.
Old 09-28-2016, 11:31 AM   #7
Rewards Points: 174
So to get ready for winter I bought this foam spray insulation. I just want to seal up the room so it isn't so cold. I'll have to look at how to really fix it next summer. The question I have is would you seal it inside the room or outside or both? I am in NM so most things dry out, but there is a chance moisture is in between the walls.
Enclosed entryway is leaking how to seal?-1475079179490.jpg   Enclosed entryway is leaking how to seal?-1475079211762.jpg   Enclosed entryway is leaking how to seal?-1475080197496.jpg   Enclosed entryway is leaking how to seal?-1475080229566.jpg   Enclosed entryway is leaking how to seal?-1475080261408.jpg
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 11:58 AM
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 09:22 PM
How to seal a leaking foundation crack from the home's exterior brokenhammer Building & Construction 5 01-02-2011 09:08 AM
Seal for a leaking hot water heater safety valve topspinken General DIY Discussions 9 10-14-2009 03:51 PM
To seal or not to seal tops of IPE rocketdoctor Building & Construction 3 09-20-2009 12:04 AM
