Electric Meter - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-01-2013, 05:06 PM   #1
electric meter
Do I need to remove the meter to put siding under or can I side around it for codd issues
buck545 is offline   Reply With Quote
Old 08-01-2013, 05:12 PM   #2
kwikfishron's Avatar
Rewards Points: 90
It depends but usually not. What's behind the meter now? What type of siding?
kwikfishron is online now   Reply With Quote
Old 08-01-2013, 05:19 PM   #3
Its a cinder block house...going to install 1 inch strips to attach the siding to
Old 08-02-2013, 02:11 PM   #4
I did my own siding last year and didn't want to remove power box so just put trim around it like the windows and doors.
If for some reason it ever has to come off then I can remove the trim and put siding up.
dabeast is offline   Reply With Quote
Old 08-02-2013, 02:21 PM   #5
Rewards Points: 12,856
Got a picture? Part depends if the meter is mounted to a base or to the wall.
Old 08-02-2013, 10:13 PM   #6
firehawkmph's Avatar
Rewards Points: 1,800
Last time I sided an older house, the owner was getting a new service installed, so the electrician on the job left the new base with the meter loose so I could install a mounting block behind it. Don't remember if I got the block at the siding warehouse or the electrician brought it. But it was like one of these: http://www.lowes.com/pd_89145-44645-...%7C1&facetInfo=
Bigger version of the J-blocks made to mount light fixtures and the like. If you're furring out the block 1" you would want to run the furring and then mount the block to the furring.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
200 Amp or 400 Amp service Boontucky Electrical 37 07-24-2011 01:33 PM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 07:00 PM
Electric meter garyoutwest Electrical 1 10-02-2009 05:10 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
