Okay here's the problem. I have a colonial style house with cathedral type ceilings on second floor. When house was built the soffit vents were covered up with insulation. I have tried unsuccessfully to try and wedge my body into the space in the attic to try and pull it away from those vents but I cannot reach anywhere near due to the low roof where it meets the framing for the ceiling for the rooms below. also the holes cut for the vents on the outside are too small to fit my hand up into to try and pull insulation out. A solution offered to me is the edge vent or dci venting about three feet up from roof edge due to the dormers being in the way and the fact that insulation would still be a problem. The theory is that with my passive vents at top and new vents near bottom that it would work the same or at least regulate temperature better than what I have now without creating a more expensive and time consuming solution. Any thought or ideas. Live in Northwest Illinois
