Edge Of Roof Rotten - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-06-2009, 11:32 AM   #1
Edge of roof rotten
The 12 year old roof on my garage is kaput, mostly sun damage on the west exposure and I discovered that their was no first course laid and as a result the first few inches of the OSB are like bad cheese. Can I cut up 16" or so from the edge and just replace this piece or do I have to pull off the full sheets and replace ?
skloon is offline   Reply With Quote
Old 05-06-2009, 03:25 PM   #2
I feel that anything less than 24 inches wide leads to problems with dimensional stability, so go at least 2 feet up with the wood decking replacement.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-06-2009, 05:54 PM   #3
H-clips
whether you take off 16" or 24", use H-clips between your new wood and what remains of the old and sag won't be an issue.
VaViaCo is offline   Reply With Quote
How to hang screws from soffitt - the underside of the outer edge of the roof Synthia212 General DIY Discussions 5 03-10-2009 05:08 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
