"the Edge" Edge Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2009, 09:08 PM   #1
"the edge" edge vents
Has anyone here used "the edge" edge vents made by AirVent, Inc.? They're black plastic vents that go on the edge of a roof with little or no soffits. I hear two sides of the story...that they are great, and some people say they can actually cause ice dams....
Any input would be much appreciated...
If the ice damming is a possbility, my other option right now is the vented gutter apron or vented drip edge made by the same company, AirVent, Inc.
Thoughts?
k.kuenn is offline   Reply With Quote
Old 06-23-2009, 10:26 PM   #2
I don't like the Vented Drip Edge, because the louvres are right on top of the gutter where the ice builds up.
Do you have a link to a "Vented Gutter Apron"? thats a new one to me.
There is vented fasia boards made by Crane Building Products.
Also, there id vents that go between the fascia and a sub-fascia that can still have gutters installed, if that is your biggest concern.
For me, personally, I like the Smart Vent, by DCIproducts Inc., and have been using it since 2001 with no problems.
http://www.dciproducts.com/html/smartvent.htm
The additional airflow created from the proper Intake Ventilation minimizes any snow melt on the roof surface.
Search this forum for photos I took right immediately after both 6" and 14" snow fals with houses that I installed the Smart Vent on.
But, I am a firm believer in the Shingle Vent II for the best results for Ridge Ventilation.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-25-2009, 11:30 AM   #3
Thank you so much, Ed. I wasn't sure if it was called a vented drip edge, or vented gutter apron. Since you haven't heard of it, "vented drip edge" was probably the correct term.
I will definitely check out the DCI edge vents.
We're also doing ridge venting, as well so I think after this we'll have a good set-up.
Thank you very much for the input!
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 08:12 AM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 10:17 AM
Removing some vents rdmccaw HVAC 4 10-22-2008 02:00 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 06:02 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
