Eave Vents, How Much NFA Per 2" Hole? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-07-2012, 07:49 PM   #1
Eave vents, how much NFA per 2" hole?
Hello folks,
I'm trying to calculate how many holes to drill in the 2"x6" blocks of my eaves in a 11'x15' detached workshop that has a 4:12 hip roof. It will be insulated and drywalled.
I'm trying to balance the attic ventilation and will be using the 1/300 calculation instead of the 1/150.
It looks like the NFA (net free area) of the attic requires 40.32 sq inches for the exhaust and the same for the intake.
I'm looking at installing a static roof vent that provides 41 sq inches of NFA.
Then I plan to drill 2" intake vents at the eave blocks but need to know how many to drill.
If I've done the math correctly, a 2" hole is 3.14 sq inches in area, which would mean 13 2" holes for intake.
Can someone verify this? Is there a reduction in the area when screened with 1/4" wire mesh?
Thanks.
RM575 is offline   Reply With Quote
edge vents or dci vents globex Roofing/Siding 2 08-18-2011 08:17 PM
Eave vents without soffit NHoepner Roofing/Siding 3 07-29-2011 09:03 AM
Need help shopping for soffit vents and baffles kmc HVAC 2 05-02-2011 06:23 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 05:02 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
