Dumpster Size - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-19-2012, 01:42 PM   #1
dumpster size
I need a dumpster for shingle removal for a 2100 sq.ft. roof with two layers of shingles. How large a dumpster do I need?
DigDug1956 is offline   Reply With Quote
Old 10-19-2012, 06:02 PM   #2
ParagonEx's Avatar
Rewards Points: 150
You will need a 20 cubic yard dumpster.
ParagonEx is offline   Reply With Quote
The Following User Says Thank You to ParagonEx For This Useful Post:
Windows on Wash (10-19-2012)
Old 10-22-2012, 02:30 PM   #3
Grumpy's Avatar
Rewards Points: 508
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Generally speaking I use the following rule of thumb, 1/2 yard per square. A 21 square roof with two layers would follow this formula: .5 x 21 x 2 = 21 yards. This .5 yards per square is on the high side and will leave you room for cut offs, packaging, felt, etc... If I were ordering a dumpster I would order a 20 yarder and would have room to spare for neighbor's donations.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 02:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 08:18 PM
Dumpster Size For Tear down cbzdel Building & Construction 8 10-10-2011 11:26 AM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
