Dripedge Placement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-26-2013, 11:01 AM   #1
Rewards Points: 1,062
dripedge placement
People,
on the bottom edge of a hip roof , do i pop in a drip edge under the felt AND shingles or above felt?? Also, can I secure just with caulk roof tar or need nails?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-26-2013, 12:40 PM   #2
Rewards Points: 2,238
Under the felt -
secure with nails.
Should be under, some type of "Water Shield" - not felt.
Aluminum drip-edge - aluminum nails
Galvanized - galvanized nails
"RF"
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Windows on Wash (03-26-2013)
Old 03-26-2013, 05:00 PM   #3
Rewards Points: 13,300
That drip cap should be used on the whole roof not just the lower edge.
Need to go back and add your location to your profile.
Just go to Quick links and edit.
Most areas call for Storm and Ice shield on the lower edge.
Old 03-26-2013, 09:24 PM   #4
Roofmaster
Rewards Points: 2,172
Stick an 8 inch strip of ice dams down to the sheathing, at the eaves, hang it two inches below lower edge of sheathing. Install drip edge and nail 24 inches on center. Hand Nail, 1/4 inch in from the back of the metal drip with roofing nails. Metal moves a lot with thermal change, and it will rack the nails if you install too many, too close together. Overlap drip 2 inches on its ends and do not nail through the lap. Install a full roll of ice dams extending down to break in drip, and continue up slope with ice dams to 2 ft inside exterior wall line, continue from there up with shingle mfgr approved underlayment. cut 6 inches off first starter course and hang 1 inch past break in drip. continue on across. Install first course hang 1 inch (Knuckle) past break in drip. All metal edge strips (Rakes and Eaves) get metal edge enveloped like this. Shingle metal at rakes.
The mistake most people make is over nailing accessory metal, and nailing in the laps. You have to allow metal to move, because it is going to whether you like it or not.
Good luck.
Furniture placement question tamjamb Interior Decorating 14 08-23-2012 09:52 AM
Ideas on driveway/home placement mandg Building & Construction 9 07-02-2012 08:01 PM
Question about vent placement Sweet Lew Roofing/Siding 8 07-01-2011 11:43 AM
Rules for furniture placement for a living room? Bacardi 151 Interior Decorating 17 12-23-2008 11:49 PM
Sub-Panel Placement Question KC10KEVIN Electrical 10 05-09-2008 10:40 AM
