Drip Edge For Top Side Of Shed Style Roof With Metal Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-05-2011, 07:22 PM   #1
Rewards Points: 150
Drip edge for top side of Shed style roof with metal roof?
I am building a shed. its all framed. Shed style roof 2x6 rafters 24 oc. with 2x4 purlins spaced 24 o.c. over them. So my question is how to seal that top lip so water doesn't run down the underside of the roof. Is there a drip edge or flashing that attaches over the top of the roof and to the front facia (which isnt up )???
organick is offline   Reply With Quote
Old 09-06-2011, 08:26 AM   #2
Rewards Points: 1,440
Yes. You use the same drip edge that would go on the lower (eave) edge of a regular roof. The vertical flap is wide enough to carry the water below the edge of the roof sheathing and top of the fascia board.
Old 09-06-2011, 08:58 AM   #3
Rewards Points: 150
If your rafters are 2x6 and your purlins are 2x4 you will need 1x8 (3/4" x7 1/2" actual size) fascia board which will set to the top of the purlins and the roofing drip edge goes over the fascia board at the top, otherwise the roof drip edge will not cover the 2x4 purlins you don't want a gap there at the bottom of the purlins that the drip edge won't cover which will let water run behind the fascia.
guest is offline   Reply With Quote
Old 09-06-2011, 10:47 AM   #4
Rewards Points: 150
i know that.....i just need the actual drip edge metal that goes over the metal so there is no gap between metal and wood on top.... Allan a normal drip will cover the raised metal too? what about colors though?
Old 09-06-2011, 10:53 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
if your using a corrugated panel you need a closure strip that sits above the drip cap,if your using a standing seam panel the ends of the roofing are folded and locked into the drip edge
Tom Struble is offline   Reply With Quote
Old 09-06-2011, 11:22 AM   #6
Rewards Points: 150
corrugated panel..... closure strip between roof and purlins and the drip edge just on the facia??? or a drip edge over top with the strip closure between that and roof??? I never used metal on shed style roof before. thanks
Old 09-06-2011, 01:33 PM   #7
Need to show a picture of what the roof sheathing looks like and how much of a gap needs to be covered. Is this a vent gap comparable to a ridge vent on a peaked roof?
Old 09-06-2011, 01:43 PM   #8
Rewards Points: 150
not for venting at all I dont have a pic but this one attached is the basic style. has the overhang in front....mine has closed doors though. Its 2x4 purlins over the rafters and the panels will be screwed to that. I need something to stop the water from coming over that top edge and running down the underside of the roof.
Old 09-06-2011, 02:20 PM   #9
kwikfishron's Avatar
Rewards Points: 174
You just cap it with metal.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (09-06-2011)
Old 09-06-2011, 04:46 PM   #10
yes like ron says,i was thinking something else
i would still use a closure under the cap on the downwards slope
Old 09-06-2011, 09:43 PM   #11
YOu can get metal drip edge with a premade fold to fit over the front edge of the plywood roofing down enough that the water drops off the metal edge and does not end up on the underside of the plywood roofing.
In your picture there is someting folded over the front of the shed. The drip edge I mentioned is the same idea but it only needs about one inch folded over the front to cover the edge of the plywood roof panels.
Shed Style or Truss? my5sons Building & Construction 42 08-04-2015 06:33 PM
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 10:04 AM
Not venting a metal roof. maestro Building & Construction 16 12-13-2011 03:31 AM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing/Siding 2 09-12-2008 09:51 PM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
