Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-17-2012, 02:46 PM   #1
Drip edge for shed door?
I need to add a drip edge (drip cap) over the door on my shed.
I was thinking of using this (reversed of course):
http://www.homedepot.com/h_d1/N-5yc1...1#.UFdvt67TfKE
or this:
http://www.homedepot.com/h_d1/N-5yc1...9#.UFdv1q7TfKE
Neither of these is really for mounting over a door, but both look like they might work. The first one would be mounted opposite to how it is on a roof edge (the long side on the wall). The second one is 2" so would be my preference.
Any thoughts?
garya505 is offline   Reply With Quote
Old 09-17-2012, 05:10 PM   #2
chb70's Avatar
Need a pic to see exactly what you are trying to accomplish. If you install a drip cap how are you going to seal the wall side of the cap, because if you are just going to calk that area then it would be a better idea to remove the trim and back caulk, then run a bead of caulk on top of the trim.
Can You Dig It!
chb70 is offline   Reply With Quote
Drip edge overlap Mark Harvey Roofing 2 09-04-2012 09:54 PM
Drip edge / rail solution for flat concrete deck jjnero Roofing 1 07-19-2012 05:02 PM
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing 4 10-24-2010 02:18 PM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
Drip edge mattflytx Roofing 3 09-09-2007 11:53 PM
