Drip Edge Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2014, 06:21 AM   #1
Rewards Points: 14
Drip edge questions
Have a 48 ft stretch of gutter on the rear face of our house which slppes towards both ends. It was installed after the house was built so the drip edging is behind the gutter, plus with the pitch needed it drops below the drip edge anyhow. Gutters seems to work fairly well but i am getting some weeping between the soffit and the gutters backside. Any thoughts on the best solution? You can see water sheeting down from the drip edge to back behind the gutter during heavy rain...
Sent from my Kindle Fire using Tapatalk 2
Buck268 is offline   Reply With Quote
Old 05-07-2014, 06:42 AM   #2
Rewards Points: 14,000
How far are the shingle over hanging the edge of the roof?
They sell a simple L shaped flashing just for this.
Sort of looks like regular drip cap but the side that goes on the roof is longer so it can slide up under the shingles.
Old 05-07-2014, 07:20 AM   #3
roofermann's Avatar
Rewards Points: 401
A good gutter hanger would have put the back of the gutter behind the drip edge. Joe has the right idea for a repair, short of re-hanging the gutter.
roofermann is offline   Reply With Quote
The Following User Says Thank You to roofermann For This Useful Post:
Windows on Wash (05-07-2014)
Old 05-07-2014, 07:22 AM   #4
Rewards Points: 14
Not far about the same amount the drip flashing protrudes.
Should installed drip edge cover fascia board? dilerin Roofing/Siding 12 11-04-2012 02:03 PM
Question about metal roof on shed and drip edge genEus Roofing/Siding 8 09-30-2012 09:27 AM
Drip edge overlap Mark Harvey Roofing/Siding 2 09-04-2012 08:54 PM
Drip edge / rail solution for flat concrete deck jjnero Roofing/Siding 1 07-19-2012 04:02 PM
roof/wall drip edge interface? wombosi Building & Construction 1 05-15-2011 05:42 PM
