Drip Edge Metal - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-19-2009, 05:04 AM   #1
Rewards Points: 35
Drip edge metal
My flat roof (1:12) has 1" x 6" fascia board that creates a 4" parapet because it is nailed to the 2" deck edge.
Is this correct after tear-off:
1. Install cant strips around perimeter.
2. Base sheet and torched material travel the deck and up the 4" parapet wall.
3. Drip edge metal (in the shape of a inverted "U") fitted over the fascia/roof covering material and nailed to the fascia board.
Anything missing?
TVC15 is offline   Reply With Quote
Old 10-19-2009, 07:07 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Sounds correct. Hidden continuous cleats would be better.
tinner666 is offline   Reply With Quote
Old 10-19-2009, 02:27 PM   #3
Rewards Points: 35
Can you explain the cleat and how/where it fits into the new roof material?
I searched the forum - could not find description, size, weight, how to fasten, where to buy, etc.
I am doing 1/2 (4 squares) of the roof and, have to maintain the same profile and roof line on the front (I am reusing the carefully removed, 20 year old, custom made drip edge.)
Photo attached.
Old 10-19-2009, 03:06 PM   #4
Pro Slate Roofer
tinner666's Avatar
I hope this helps. There are variations on this theme too.
http://www.pac-clad.com/products/per...s-cleat-coping
http://www.bbsheetmetal.com/copper-r...ng-system.html
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 06:04 AM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 11:49 AM
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 10:28 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
