Drip Edge Leak -- Bad Installation? Something Else? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-13-2012, 04:34 PM   #16
Doing This Way Too Long
Rewards Points: 532
Pretty sure I know about where you live. Those built-in troughs are quite common in places in the NW. Not very common in other areas of this country which is why so many don't recognize it. You don't necessarily have an improper installation, just a fault somewhere since it is isolated to a specific area.
I've seen where it is not wrapped up and over properly in areas and excessive weather (heavy or windblown rains) will cause infiltration. It does require getting up there and inspecting the area around it for that or for splits in the membrane etc.
The "drip edge" really does nothing but finish off the look. Your main concern is the integrity and proper installation of the membrane. It's really nothing more than a 3-course (mastic and webbing) repair once the area is located.
A better picture directly in front of the area would really help if that's possible.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
t60 (03-13-2012)
Old 03-13-2012, 05:13 PM   #17
t60
Rewards Points: 125
Thanks -- it's refreshing to see posts that are actually trying to triage the issue rather than throw money at it.
My neighbor let me up his roof and his setup was exactly like mine -- I could not tell the difference.
I'll try to get a better picture of the front, though it might be difficult due to the rain this week (probably too dangerous to climb up the ladder with the wind gusts).
t60 is offline   Reply With Quote
Old 03-13-2012, 05:57 PM   #18
Rewards Points: 532
First things I would look for are a lap seam in the membrane around that area and possible splits or damage in the membrane. If there is a seam, stepping on in will tell you if it's leaking. It could just be one small area but it gets underneath, hits the underlayment and wanders til it finds its way in.
To check the edge the metal will have to be removed. Underneath it the membrane should roll over the top of the ledger and down the face. Unless it's a modified sheet sometimes bending the membrane over sharp angles can crack it.
If it's leaking all the time I suspect one of the first two issues. If it's leaking only in extreme weather incidents I would suspect it's a perimeter issue.
I also noticed some kind of odd transition in the trough in your pictures. Is the leak anywhere near this area?
edit: I see you said in heavy wind and rain. If your detail you drew is correct then it is installed wrong. The membrane should be up and over the face, not ending where you have it ending. then the edge metal installed basically just to hold the membrane down. Pull that piece off and see if the membrane is lapping over and see if it is split at the bends.
Old 03-13-2012, 06:44 PM   #19
RFN-4A-LVN
Roofmaster417's Avatar
My intentions were not to disappoint you within the thread.Personally I have never seen a set up such as yours.Money does not grow on trees true and I was only trying to offer a solution.If I offended you.,my fault.
In the south and in my area I have found when people try to include Awa plan or other types of membrane converting a roof system material into a gutter system material it is a mask and eventually ends in more damage than had it been installed according to standard code compliance installations.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
tinner666 (03-15-2012)
Old 03-13-2012, 06:53 PM   #20
t60
Rewards Points: 125
No offense taken, just frustrating to see my house leaking and honestly I'm just looking to get a quick fix right now since we're getting late winter rain. I think we have the same intentions -- if it were up to me I would get it re-done properly and have it last, but like you say, money doesn't grow on trees.
The Following User Says Thank You to t60 For This Useful Post:
Roofmaster417 (03-13-2012)
Old 03-15-2012, 02:46 PM   #21
t60
Rewards Points: 125
I went into my attic yesterday and upon reviewing the entire perimeter, and only this 3 foot section is leaking. I have a feeling I know what my roofers were getting at -- it looks like the rain is getting into a gap next to the downspout. I followed the trail of water in the attic and it stops right where the downspout is. I did not see any water under the shingles.
The rain hasn't been very helpful, so I haven't climbed up to verify it yet, but strongly believe there is some kind of water penetrating that area. I'm going to buy some roof patch and patch over any holes on the downspout (whenever it stops raining -- possibly next weekend), and I'm really hoping that fixes the issue.
Old 03-18-2012, 11:26 PM   #22
t60
Rewards Points: 125
Just wanted to provide an update -- I think I know what the problem is now, and it's got nothing to do with the drip edge or the shingles.
Here's what I saw this past weekend:
The orange arrow is where I think water is infiltrating. Sorry I forgot to get a better angle, but if you can't tell, this is a fascia board that the old roofers cut into for the drop outlet, and it looks like they cut way too much. They cut a huge square and there are very obvious holes exposed which allow water to come into the attic. I'm about 95% sure this is the culprit -- what I may do temporarily is patch it up and wait until it rains (tomorrow).
I don't know how I missed this pretty obvious hole, but I was too focused on the drip edge rather than the downspout. I guess that's why I'm not a roofer!
Old 03-19-2012, 08:52 PM   #23
Metal Roofing
Rewards Points: 600
If the leak continues:
Isolate the area ( measure with a tape) and provide pics of that along with an over all pic of the area. The inital pic you posted shows us the general roofing situation you have, but not where the leak is. You will get 10 different posts about what it could be leaking from and all could be wrong. Help us help you
AndyWRS is offline   Reply With Quote
Old 03-27-2012, 02:31 PM   #24
t60
Rewards Points: 125
I'm going to call in one of the roofers to fix this. I was staring at the roof with a hose for about an hour and just could not find the leak. It seems like the fascia boards themselves are old and are causing the leak, but I can't see any leaking points from the outside. The shingles look brand new and even after dosing it with water (gallons worth) the built-in gutters never got full to the point of reaching the drip edge.
It's probably going to cost me a few hundred bucks easy, but I'll just have a professional deal with this one. It's been 2+ years living with this leak and it'll be worth getting this headache fixed.
Old 03-27-2012, 05:28 PM   #25
RFN-4A-LVN
Very small price for some piece of mind.I bet you are completely sick of this issue in your life.
A couple years is a long time of built up frustration.,who knows maybe some sky diving or bungee jumping is in your future ?
I recommend a 7,000-14,000 foot jump to clear your mind and give a new outlook on your new found freedom.Nothing clears the mind better than hurling towards the earth @ 120 mph +.
drip edge vs. asphalt felt amakarevic Roofing/Siding 1 04-14-2011 09:58 PM
Overhanging Drip Edge Columbus Roofing/Siding 11 03-29-2011 09:32 PM
Can I install a drip edge on this roof myself? housenewbie Roofing/Siding 1 01-25-2011 06:57 PM
Newly Installed Roof Drip Edge question w/pics searayrunner Roofing/Siding 30 06-17-2010 12:14 AM
Opinion on my drip edge installation crza1 Roofing/Siding 5 02-15-2010 01:50 PM
