Drip Edge And Gutters. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-05-2013, 12:43 PM   #1
Drip edge and gutters.
I had to replace fascia and gutters on my house.
In doing so I had to remove the drip edge as it was nailed to the fascia board.
So now i'm in the process of replacing the drip edge. Should I use a drip edge with a kick out like what was there before or should I just use a flat piece (gutter apron i think)?
Thanks,
dabeast is offline   Reply With Quote
Old 09-05-2013, 02:59 PM   #2
I would use gutter apron. It will hang down lower onto your fascia so that the rear lip of your gutter can tuck behind.
Yeti is offline   Reply With Quote
Old 09-05-2013, 03:52 PM   #3
Rewards Points: 154
I think gutter apron is mostly recommended on rooves with less of a pitch where gravity alone won't keep most of the water wicking back under the shingles, or where there isn't enough shingle overhang. It is not NECESSARY in alot of other cases but it never hurts, and is generally a better option. If drip edge is used instead of gutter apron extra care must be taken to make sure the gutter falls under the drip edge everywhere along its length. Even then, a few drops will still roll behind it and down the fascia. With gutter apron water coming down the shingles and slipping behind the gutter will never be a concern.
eharri3 is offline   Reply With Quote
Old 09-05-2013, 05:47 PM   #4
So I shouldn't worry about capillary action on the gutter sides if I use a gutter apron style edge instead of a drip edge that cuts back in (D style?)
Use this on gutter side http://www.homedepot.com/p/Construct...9#.Uij72jakoeg ?
Old 09-06-2013, 02:15 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
D edge is used on gable ends, apron on eaves with gutters.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 10:04 AM
Vented Drip Edge problem vadifey Roofing/Siding 5 08-29-2012 04:20 PM
Gutters leaking with drip edge. Help! hansmike Roofing/Siding 6 10-10-2010 07:02 AM
new drip edge over existing gutters scheiman Roofing/Siding 1 06-05-2010 08:44 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 11:49 AM
