Drip Edge/Gutter Apron Nailing Pattern? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2010, 09:08 PM   #1
What is the CORRECT way to nail drip edge/gutter apron?
I was thinking fewer nails may be better to prevent buckling due to different expansion properties from the decking.
Is approximately 2" of overlap correct? Should a nail be placed on this lap?
I understand nails should be placed only into the decking, not into the fascia. Also, below any Ice/Water Shield & underlayment on eves, above on rakes. (Please correct me if I am wrong)
Last, I understand gutter apron should not be snug against the fascia to aid fascia installation. I was thinking to carry a small scrap of 1/4" plywood as a spacer during application, does that sound about right?
Thanks in advance for your responses, I could not google up this info, so this will (hopefully) become a good reference for others seeking the same info.
echase is offline   Reply With Quote
Old 03-16-2010, 11:09 PM   #2
Commercial Roofing
AaronB's Avatar
I like to nail the apron every two inches in an offset pattern.
Wrap the ice barrier down onto the fascia then put your apron on.
Do not nail the apron overlaps, or any other metal overlaps.
Install the fascia before the roof.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Drip Edge/Gutter Apron & Electrolyses echase Roofing/Siding 1 03-13-2010 02:59 PM
Crown moulding nailing and blocking pattern Klawman Carpentry 2 01-13-2010 11:22 AM
Installation of gutter apron over existing apron dbosh Roofing/Siding 4 11-13-2009 09:44 AM
drip edge/gutter apron? ponch37300 Roofing/Siding 1 05-21-2008 11:30 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
