Drip Edge, Etc. Will This Be OK? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-28-2012, 02:25 AM   #1
Rewards Points: 1,092
Drip edge, etc. Will this be OK?
I've been reading here a bit, and think this will be fine. But... Situation: No, there is no I&W shield planned. This is a shop that will be used infrequently when it needs to be heated, and then it will neither get real warm nor for more than several hours at a time. I therefor don't think the I&W would be beneficial, and it is 10 below right now w/ slight frost on the plywood no matter how much I sweep. The I&W would never stick. I've gotta get this puppy closed in before the temp drops. I will be doing a good job air sealing, too, to avoid moisture escaping the conditioned (rarely) space. The facia board is drawn a bit funky, but it will be a normal 2x6 beveled on the bottom for drip collection. I am planning on leaving a small gap between the drip edge and the plywood so the plywood can be re-treated now and then w/ facia. There will be no normal gutters; 3' overhangs and likely ground gutters instead. Ply will overhang the facia by 1/2", D-drip will stick out 1/4" from ply, and shingles will overhang D-drip by 1/4-3/8". Goo will go between D-drip and felt, and starter shingles will be generously goo'd (next spring). Thanks for any comments.
Old 11-28-2012, 07:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
I think you are fine.
Ice and Water is a Band-Aid response materials to poor building and ventilation.
You know more than 99% of the roofers out there so I think you are golden.
Old 11-28-2012, 09:44 AM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
People saving $75 on ice shield, for the loss.
That's how I would install the drip edge if I were only installing felt. "Water rolls down hill, pay day is on Friday. If you remember that, you'll be ok." That's what I tell all new guys on day one. So if water gets under the shingles and rolls down the felt it will roll out, rather than roll behind the drip edge if the drip edge were installed over the felt. However if you are installing a gutter, I would disagree with your design and once again encourage ice shield.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 11-28-2012, 10:16 AM   #4
I agree that Ice and Water is recommended, just not sure it is a must if he isn't heating the space.
Old 11-28-2012, 11:36 AM   #5
Thanks all. I will install I&W on the house, but agree w/ WOW that if you have properly air sealed then no vapor will be getting to the roof. But, for stink and giggles, it is probably a good, cheap and easy to install insurance member.
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 09:04 AM
Drip Edge over top of sand-asphalt roll at sloping edge Fun Value Roofing/Siding 0 04-08-2012 12:31 AM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
