Drip Edge For 2 Layers Of Roof Sheathing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-03-2011, 04:30 PM   #1
Cow
Drip edge for 2 layers of roof sheathing?
I just tore the roof off down to the 1x6 planks. The planks are checked/cracked in some places causing a lot of nail pops in the old shingles. I'd like to go over it with 1/2 CDX but the d metal drip edge I bought won't cover the combined thickness of both. What does everyone do to handle this?
Thanks for the help.
Cow is offline   Reply With Quote
Old 07-03-2011, 06:53 PM   #2
Framing Contractor
Rewards Points: 118
They make a wider drip edge. Go to a roofing supply house.
sixeightten is offline   Reply With Quote
Old 07-06-2011, 11:13 AM   #3
Grumpy's Avatar
Rewards Points: 524
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I personally wouldn't install the sheathing over the decking unless it were spaced decking. May be better just to refasten what's loose and replace what's damaged or rotten. Then again we install 1/2" CDX plywood over spaced decking on a regular basis. When we do, we install a wider drip edge that we often custom bend ourselves.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-06-2011, 09:07 PM   #4
Cow
Thanks guys.
I'm going to do like you said Grumpy. I'll replace the bad boards and make sure to fasten the loose ones down instead.
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 05:04 AM
Gutters leaking with drip edge. Help! hansmike Roofing/Siding 6 10-10-2010 06:02 AM
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 09:28 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 01:02 AM
warped roof sheathing arizonahiker Roofing/Siding 13 11-17-2005 12:53 AM
