Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-15-2006, 06:14 PM   #1
Drip Cap or Drip Rail
I'm in the process of replacing facia board around my home. I've removed all of the existing facia board, however, much of the drip rail has been bent. I would like to remove the existing drip rail by using a putty knife to raise the shingles and a sawzall to cut the nails in order to remove the drip rail. My question is, can this be accomplished in this manner and could I slip a new drip rail under the existing shingles and secure it with roofing cement? Thanks for your input. This may also answer the previous post.
joe3534 is offline   Reply With Quote
Old 11-15-2006, 08:13 PM   #2
What is the reason to replace the fascia?
Drip edge = drip rail
redline is offline   Reply With Quote
Old 11-15-2006, 08:14 PM   #3
Facia was replace due to damage from dry wood termites.
Old 11-15-2006, 08:17 PM   #4
Do you have three tab style shingles?
Old 11-15-2006, 09:03 PM   #5
Dimensionals
Old 11-16-2006, 01:25 AM   #6
Log-Style Home Contractor
North Country's Avatar
Shouldn't be a problem with the way your doing it.
North Country is offline   Reply With Quote
Old 09-18-2007, 01:38 PM   #7
Hey Joe, how did it go with the roofing cement and drip rail, did it work? I am in the process replacing the facia on my house and am trying to figure out the best way to install a new drip rail.
mattflytx is offline   Reply With Quote
Old 09-18-2007, 04:38 PM   #8
If Joe tried to remove his drip edge with a sawsall he may still be in the hospital.
Removal is usually done with a couple of flat bars.
When you put back with new:
Try to get some nails in the top of the drip edge. Pre-drill a few holes might help. Lots of cement.
Use galvanized drip edge / it will take manhandeling much better then the AL.
Big Bob is offline   Reply With Quote
Adding a chair rail to dining room which is connected to kitchen Bacardi 151 Interior Decorating 7 07-05-2007 04:31 AM
Safety rail for loft Pam Remodeling 5 02-26-2007 02:55 PM
Furnace Drip!??! acawley22 HVAC 1 01-10-2007 09:36 PM
fascia and drip edge glassman General Discussion 3 10-02-2006 07:39 PM
Wall lamps and chair rail alvanos Carpentry 1 04-26-2006 12:35 PM
