-   -   Drip Cap or Drip Rail (http://www.diychatroom.com/f9/drip-cap-drip-rail-4840/)
joe3534 11-15-2006 06:14 PM
I'm in the process of replacing facia board around my home. I've removed all of the existing facia board, however, much of the drip rail has been bent. I would like to remove the existing drip rail by using a putty knife to raise the shingles and a sawzall to cut the nails in order to remove the drip rail. My question is, can this be accomplished in this manner and could I slip a new drip rail under the existing shingles and secure it with roofing cement? Thanks for your input. This may also answer the previous post.
redline 11-15-2006 08:13 PM
What is the reason to replace the fascia?
Drip edge = drip rail
joe3534 11-15-2006 08:14 PM
Facia was replace due to damage from dry wood termites.
redline 11-15-2006 08:17 PM
Do you have three tab style shingles?
joe3534 11-15-2006 09:03 PM
Dimensionals
North Country 11-16-2006 01:25 AM
Shouldn't be a problem with the way your doing it.
mattflytx 09-18-2007 01:38 PM
Hey Joe, how did it go with the roofing cement and drip rail, did it work? I am in the process replacing the facia on my house and am trying to figure out the best way to install a new drip rail.
Big Bob 09-18-2007 04:38 PM
If Joe tried to remove his drip edge with a sawsall he may still be in the hospital.
Removal is usually done with a couple of flat bars.
When you put back with new:
Try to get some nails in the top of the drip edge. Pre-drill a few holes might help. Lots of cement.
Use galvanized drip edge / it will take manhandeling much better then the AL.
