Drilling In To Stucco - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-25-2014, 07:50 AM   #1
Drilling in to Stucco
Hello all,
I recently purchased a 1945 Tudor house in upstate NY. The stucco exterior was just redone last year. I'm interested in adding flower boxes to the upper window and the lower left window. That said, I do not want to damage anything with my first project for my new house! The upper window has a timber trim under it, and the lower window just has stucco.
Is there a way to anchor a flower box to this wall without damaging it? Should I drill into the wood? Would any of this cause cracking/leaking/rot?
Thank you all!
pgsean is offline   Reply With Quote
Old 02-25-2014, 08:52 AM   #2
Rewards Points: 13,712
Drilling into the stucco or the wood is very likely to allow water in and damage it.
You get the damage from where you attach it, the splash back on the wall and an area behind it that does not dry out.
Old 02-25-2014, 12:23 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
I would not put a flower box on the front of that home and certainly not with stucco.
What size/brand drill motor do you recommend for drilling into concrete foundation Pawl Building & Construction 1 06-06-2013 09:48 AM
Drilling into stucco to install security doors careyk Concrete, Stone & Masonry 4 08-03-2012 12:52 PM
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 06:23 AM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
