Drill Holes Through Cement Tile? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-07-2012, 12:42 AM   #1
Rewards Points: 79
Drill holes through cement tile?
This may be unorthodox or what have you, but! I'm installing pool solar panels on my cement tile roof. Instead of fabricating some sort of bracket and lifting tiles to screw them down, can I drill through the tile and just use longer screws, then make sure it's sealed up well?
Dwillems is offline   Reply With Quote
Old 03-07-2012, 02:14 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Tiles just sit on your roof as it is.
If the wind ever caught those panels, I think they would take the tile with them and maybe hit your neighbor on the head.
titanoman is offline   Reply With Quote
Old 03-07-2012, 02:24 AM   #3
Rewards Points: 79
I'm not meaning to fasten the panels directly to the tiles themselves. I'm thinking drilling all the way through the tile, and using a long screw to secure the panel brackets directly to the underlayment.
Old 03-07-2012, 02:40 AM   #4
Disabled wood vet
titanoman's Avatar
I think you need those screws to catch the rafters, not just the sheeting.
Is it 3/4" skip or ply?
Are they a flat tile or a Spanish profile?
Old 03-07-2012, 03:46 AM   #5
Rewards Points: 79
Flat tile, I have no idea what thickness the ply is.
Old 03-07-2012, 07:07 AM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
They'll leak. And have to regularly be recaulked. Some of the tiles will also crack when being drilled. Will you be able to recaulk all the holes? Or will you have to remove panels each time? Are you going to mind water dripping in your living room sometimes? You'll have to repair the ceilings at intervals.
If you don't mind all the maintenance, it can be done.
Since the panels are supposed to last 20 years, the only way I install them is to remove the roof and correct any deficiences and install the proper brackets at the specified intervals as the new roof goes on. That way it's done and the homeowner doesn't have to recaulk every so many months.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
OldNBroken (03-07-2012)
Old 03-07-2012, 12:38 PM   #7
Rewards Points: 79
Ok, thanks. I guess I'll just pull the tile, install the hardware, and replace the tiles. It's actually not that hard, I was just hoping there was a way around it
Old 03-07-2012, 09:46 PM   #8
Metal Roofing
Rewards Points: 600
wow, we just did a relay for a customer whos pool solar was installed by drilling thruough his flat tiles into the plywood. Part of our contract was to make a bracket ( overkill ) that was lagged into the plywood then came out in between the tiles..ie no penatrations. This is what he wanted, makes sense though. The customer installed 2x4 or 2x6 blocking from in the attic at each point ( 29 of them) where the solar was attached.
It worked well, but it was a lot of work. Just remove the tiles and use the hardware and straps ment for this purpose. The bracket was not needed, he had the proper hardware it was just installed incorrectly from the get go.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
ben's plumbing (03-07-2012)
Old 03-07-2012, 09:50 PM   #9
Rewards Points: 582
yes remove tiles as required for install ..if done right you sleep good at night
Old 03-07-2012, 11:50 PM   #10
Rewards Points: 79
The brackets that came with it are L shaped, and meant to be screwed directly to the roof. Then the panel has slots that slides that slides over the L. That holds the panel from sliding down. Then a nylon strap 1" wide is strung from the bracket to the bottom of the panel to hold it from flapping around. The straps are a kit you have to buy separately for $50. Screw that! I bought 60' of that strap, and grommets for $25. I put the grommets on the straps, screwed them to the roof under the tiles, and threw the brackets out. I made two straps per, one to replace the brackets and one to hold the whole thing down. When those straps get weathered I'll probably make some custom metal brackets, but I'm glad I got the thing installed.
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
bathtub vs. cement board for tile amakarevic Flooring 6 11-14-2011 07:46 PM
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 11:31 AM
Help with drilling large holes in marble tile crashley1784 Tiling, ceramics, marble 4 03-02-2010 03:25 AM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 11:32 AM
