Drains In Dutch Gutters For Epdm Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-13-2012, 08:06 AM   #1
drains in dutch gutters for epdm roof
Twelve years ago I installed a epdm roof on my house - an 1870's victorian. The roof has about a 2/12 pitch and has a trough around the edge to help collect rain water. The roof works great, except where the water drains to the gutters. At those spots the water leaks into the attic below the drain. When we installed the roof we turned epdm pipe boots upside down, and glued the epdm over the boot. The "spout side" of the boot enters 4 inch PVC pipe going to a collection box and gutter on the side of the roof. To spot the leak I've used epdm spicing tape, caulk, uncured rubber to seal and patch. I've succeeded in stopping the leak in 1 of three drains. I'm out of ideas. Can you help?
Mike Lopez is offline   Reply With Quote
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 11:57 AM
Flat roof drains shazapple Roofing/Siding 4 08-12-2011 09:44 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
roof leaking behind gutters bigg_red1 Roofing/Siding 19 04-20-2011 05:06 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
