Downspouts Draining To Lower Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-30-2014, 08:17 PM   #1
Rewards Points: 366
Downspouts draining to lower roof
What do you usually see on how the drainage is set up from upper to lower roof?
Here's an interesting article I came across:
http://www.buellinspections.com/gutt...nd-downspouts/
Anyone seen a metal tray for the downspout that drains to lower roof (the last photo on page)? A comment (at bottom) on that page mentions such a tray is custom made by a gutter installation contractor, and is actually secured on the roof as well (comment describes specifics).
daluu is offline   Reply With Quote
Old 11-30-2014, 08:44 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,184
I would rather see the downspout on the roof than the tray.
The Following User Says Thank You to Windows on Wash For This Useful Post:
roofermann (12-01-2014)
Old 12-01-2014, 03:44 PM   #3
Rewards Points: 366
So it's better/safer to have the downspout water potentially prematurely wear out the shingles there from extra water run-off than to have such a tray over them in the case of not extending downspout to the lower gutter?
Can you clarify the reasoning?
Old 12-01-2014, 04:48 PM   #4
The extra water will wear the shingles and most times they send the water sideways at the shingle and force it under the shingle.
As long as they are draining down the surface, they are okay but not ideal.
Old 12-01-2014, 09:12 PM   #5
Rewards Points: 366
And what would putting a tray over the shingles do? The tray is supposed to be top anchored to roof covered by a layer of shingles over the mount section, just like roof vent/pipe flashings with the bottom folding or anchored to the edge of roof or something like that.
[Ceiling stains!] Need help venting oddball roof (w/pics) Triboost Roofing/Siding 10 10-15-2014 01:07 PM
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 09:44 PM
chimney lower than roof peak higgins Building & Construction 4 12-29-2011 06:28 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
