Downspout Runoff - Underground Option - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-18-2012, 10:13 AM   #1
Rewards Points: 50
Downspout Runoff - underground option
Okay, trying to remain flexible as I go along with my gutter run-off project ...
I decided that I could get some ground "infiltration" with this method with one of my two garage downspouts (instead of just shooting it into the alley):
How To Recess Downspouts In About Four Minutes - YouTube
Took me a lot longer than the four minutes they claimed in the video, but here is what I did:
trenched and laid pipe (painted and attached elbow and plastic cover first)
adjusted drain level and buried
First section of 4" pipe is solid; second 10 feet is perforated:
4 in. x 10 ft. HDPE Corrugated Perforated Drain Pipe-4040010 at The Home Depot
Question:
I've been exploring above ground gutter extensions to run water into my yard from my house gutters, but having tried this technique, I think I want to try it with a couple of house downspouts.
I'm really focusing on getting water away from the foundation because it has suffered quite a bit of damage in the past (don't want to go with splash blocks).
What unintended/unforeseen negative consequences might there be if I use this method around my house as well?
Would the 4" perforated plastic pipe (small slit openings, not the larger round holes found in the white drain pipes) fill with grass roots to the point it becomes useless as a drain. Wouldn't the large diameter - 4"pipe - be able to keep up with root infiltration? The first 10 foot section of pipe would be solid and then transition to perforated.
Winter time (in Denver; buried maybe 4" deep) freezing up a likely problem?
I guess I could dig large capacity drain holes and place plastic drain boxes, but I think that's kind of extreme - especially if the above plan will work just about as well.
Thoughts?
thanks
Clint44 is offline   Reply With Quote
Tags
downspout runoff
Underground pathway to above ground rainwater collection EdLank Landscaping & Lawn Care 1 06-10-2012 06:01 PM
Underground downspout drainage: Water standing in my brand new drainage pipes Airgibson Landscaping & Lawn Care 15 06-06-2012 07:41 AM
Underground Downspout Extensions Mr Brandon Landscaping & Lawn Care 3 03-20-2012 10:17 AM
underground downspout extensions blocked ibgyahoo General DIY Discussions 6 06-08-2009 11:56 AM
underground downspout extensions joshm Roofing/Siding 3 05-20-2008 09:45 PM
