Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-19-2009, 12:00 AM   #1
cj
Downspout routing. Please help.
I am looking for ways to route a downspout from a gutter. With the deck steps below, I cannot lay it along the closest wall as is the case with drainage systems.
Was wondering if I can use three bends before clamping it against an open stretch of wall (pls see pic). Do I need to use some sort of hangar to support the the elbow in the middle (Elbow B)?
Or is there any other way to route it?
Appreciate some help.
Thanks,
CJ
cjf1980 is offline   Reply With Quote
Old 07-19-2009, 10:00 AM   #2
Is there an overhang where the gutter ends?
framer53 is offline   Reply With Quote
Old 07-19-2009, 11:07 AM   #3
Roofing Contractor
Leftyho's Avatar
Hi,
You will be fine. You do not need a support.
Leftyho is offline   Reply With Quote
Old 07-19-2009, 11:18 AM   #4
cj
Thanks LeftyHo.
Framer53, there is an overhang. The gutter runs along the fascia board, that ends above elbow B.
Old 07-19-2009, 04:31 PM   #5
If the overhang extens far enough you can eliminate the one elbow, othewise you will be fine.
Old 07-19-2009, 07:33 PM   #6
cj
Sure thing Framer53. It is just that the overhang is not much.
Thanks for all the suggestions.
underground downspout extensions blocked ibgyahoo General Discussion 6 06-08-2009 12:56 PM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
routing of wire in garage joey b Electrical 4 12-03-2008 10:00 AM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 07:53 PM
Adding downspout to torchdown roof Grebus Roofing 8 10-07-2007 10:50 PM
