Downspout Over Lower Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-03-2010, 07:59 PM   #1
Downspout over lower roof
I have recently purcahsed a home with a downspout that is dumping directly onto a lower level roof. I want to redirect it safely, but also want it to look nice. I could just extend the current downspout straight down to the next gutter (Option A below), and paint it the color of the roof, but that would be an eye-sore. Can I go with Option B and just make the corner with the problem downspout higher to redirect the water to the next closest downspout on the upper roof?
Thanks,
Stephen
smcclana is offline   Reply With Quote
Old 10-03-2010, 09:59 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
no you have too much water coming off the upper roof for 5'' gutter and a single 2x3 leader to handle,you could possibly go to a 6'' gutter and a 3x4 leader....maybe
Tom Struble is offline   Reply With Quote
Old 10-04-2010, 07:50 AM   #3
Residential Roofer
Slyfox's Avatar
If the reason for moving the down spout is to eliminate splashing from the gutter over the garage door area, install a splash guard there.
If it's creating an eyesore 'staining' then simply reach out the bedroom window with a bottle of roof cleaner once a year or so and spray that area down.
If it's creating a leak, than it's a roof 'shingle' or wall 'flashing/siding' problem.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 10-04-2010, 09:40 AM   #4
concretemasonry's Avatar
Rewards Points: 2,578
Unfortunately, you did not post your locarion, so all you can get is general suggestions.
The "splashing and staining" problem could be easily solved with a buried pvc pipe and pop-up drain located away from the house and to provide water for the lawn. You appear to have a nice slope for dispersing the water.
I installed pop-ups, but also had an alternate available for surface discharge when we do not get enough early snow and the ground freezes. We have a steady roof run-off in the winter due to the sun (clear and cold).
Dick
concretemasonry is offline   Reply With Quote
Old 10-04-2010, 09:12 PM   #5
Imo extending your downspout to the next gutter is your best option.I don't think it is an eysore at all,but serves a function.You will have premature roof failure where the run-off hits.
johnk is offline   Reply With Quote
Old 10-08-2010, 01:20 AM   #6
Rewards Points: 956
thats a nice looking house
federer is offline   Reply With Quote
Tags
downspout roof gutter
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
EPDM Roof Plans stubits Roofing/Siding 44 05-01-2010 12:06 AM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
Adding downspout to torchdown roof Grebus Roofing/Siding 8 10-07-2007 10:50 PM
