Downspout Extension Dents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-28-2013, 03:15 PM   #16
have him park his bicycle next to it.
Old 06-29-2013, 06:44 AM   #17
Originally Posted by Windows on Wash View Post
Isn't this going to dent when the basketball hits it?
valpd is offline   Reply With Quote
Old 06-29-2013, 07:10 AM   #18
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
Dent, no.
Once it is broken down by the Sun's UV rays, it will crack and break if he hits it hard enough but it won't dent.
Old 06-29-2013, 07:17 AM   #19
Dent, no.
Crack and break? Why would I want that over aluminum or drain tile piping?
Old 06-29-2013, 07:34 AM   #20
You asked about denting.
It will not crack or break initially but as the PVC breaks down in the sun's exposure, they become more brittle. Once they are brittle enough, they will crack if you step on them or drop a basketball from high.
Old 06-29-2013, 08:11 AM   #21
Rewards Points: 1,228
Originally Posted by joecaption View Post
Make him fix it, bet it happens les often.
Shame on you for even thinking of making the next generation responsible.
SeniorSitizen is offline   Reply With Quote
Old 06-29-2013, 09:23 AM   #22
Plumber
TheEplumber's Avatar
Rewards Points: 664
There is a downspout extension made of flat hose.
It clamps to the vertical leader and lays flat until water flow through- opens enough to allow the discharge
Here's one style-- http://www.homedepot.com/p/Frost-Kin...3#.Uc7uCfke00g
Old 06-29-2013, 09:41 AM   #23
I tried this once, but wildlife was ripping it up.
Old 06-29-2013, 09:53 AM   #24
Plumber
Rewards Points: 664
Then turn the 90 to discharge onto the walk- or use a splash bock
Old 06-29-2013, 09:57 AM   #25
Splash blocks get leaves and mulch blocking water flow. It looks like I may have to add the black drain tile back on. Only drawback is that this would be the only area the would have this type of extension. Everywhere else around my home has the white aluminum downspouts.
Old 06-29-2013, 10:24 AM   #26
Plumber
Rewards Points: 664
I would rather broom some leaves of a splash block(or your son can do it) than look at an ugly piece of black pipe- but that's me
Old 06-29-2013, 10:27 AM   #27
Problem is I'm not always there to brush it off. Plus water will be near the foundation. Not good.
Old 06-29-2013, 10:34 AM   #28
kwikfishron's Avatar
Rewards Points: 576
You could do something stackable rocks and encase the thing.
kwikfishron is offline   Reply With Quote
Old 06-29-2013, 10:49 AM   #29
How do you mean?
Old 06-29-2013, 11:22 AM   #30
Rewards Points: 576
I mean...Stack Some Rocks around it.
Clogged Downspout Extension is Buried- How Do I Solve This? sweaty General DIY Discussions 3 04-13-2012 10:19 PM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
underground downspout extensions blocked ibgyahoo General DIY Discussions 6 06-08-2009 11:56 AM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 08:30 AM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
