Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-08-2012, 09:43 PM   #1
double wall chimney
i have a double wall chimney that goes through my house
and i just had a roofing company put a brand new metal roof
on my house. when they put on the new roof on it touches
the one side of the chimney so is that going to be safe
during burning season. i was told 3 inch clearance
pj42 is offline   Reply With Quote
Old 09-08-2012, 09:56 PM   #2
Pro Slate Roofer
tinner666's Avatar
double wall chimney
Metal generally doesn't catch fire. Sounds all right.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
pj42 (09-08-2012)
Moisture on interior chimney wall, need advice stock2mal Roofing 9 07-09-2011 07:57 AM
Going through double stud of load bearing wall. poptot Carpentry 10 08-01-2010 12:59 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Moisture-proofing chimney box wall penetration faithmyeyes Roofing 3 01-06-2007 12:23 AM
