#1 |
Double roof and vent for bath exhaust
Need to install an exhaust vent on the roof for a bath exhaust fan. The only issue is that there is a wood shake roof with a regular three tab over it. Roof do for replacement in a year.
Anything special about how to make this install happen?
digitalplumber is just a name for use here, I am not a plumber! |
#2 |
Metal Roofing
If the comp is in really bad shape it will be a pita.
If the comp is ok, install the vent flashing as you normally would for a comp install, the only difference is your going to cut through the old shake roof in the process. |
| The Following User Says Thank You to AndyWRS For This Useful Post: | digitalplumber (02-14-2013) |
#3 |
If the roof is due to be changed in a year and the vent is close to a soffit or under eve could you just direct the heat out of the soffit vent? we do this a lot. just has to be pushed firmly into vent to and directed down. water and condensation should not be a problem if directed properly
#4 | |
Double roof and vent for bath exhaustQuote:
Thanks, unfortunately this house does not have a traditional soffitt. Only has blocks of wood horizontally between rafters. I thought about just exiting there but these horizontal boards are at a slight angle, so the vent would always be open.
#5 | |
Newbie Bill
If you go this route, use it only as a temporary fix until you can do it properly. Remember that soffit vents are designed to bring air into the attic which then exits at the ridge vent or roof vents. Adding a source of moisture to this airflow will, over time, lead to mold and rot issues.
Bill A DIY Noob that knows just enough to be dangerous. |
#6 | |
#7 |
Here is what the eaves look like
#8 |
Newbie Bill
Sorry about that digital plumber, my comment was meant more for others who do have vented soffits.
| Display Modes | |
| Bathroom exhaust through roof | Dugams | Roofing/Siding | 28 | 09-01-2012 03:51 PM |
| very difficult house to vent roof help please | marlowe | Roofing/Siding | 7 | 09-10-2011 12:57 PM |
| Wrong roof vent for bathroom exhaust? | vanishingson | Roofing/Siding | 18 | 04-04-2011 07:25 AM |
| Vent dryer exhaust to roof | acerunner | Remodeling | 4 | 07-15-2010 08:37 PM |
| Exhaust vent on roof | handy man88 | Roofing/Siding | 1 | 03-09-2010 11:11 PM |
