Double Layer Shingle Cracks Threw Out Whole Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-29-2013, 06:41 PM   #1
Rewards Points: 12
double layer shingle cracks threw out whole roof
Why are these shingles cracked threw out the whole roof?
is it the type of glue or something they used to bond that second layer down then in the winter time it expanded and ended up cracking?
Every single double layer section is cracked, something has to be wrong with this shingle
http://s1300.photobucket.com/user/Dn...tml?sort=3&o=2
also if anyone knows anything about the reason why this furnace exhaust is so bad that would be great help to!
i made a topic on the HVAC
Wrong metal for furance exhaust ?
Dnbtrack is offline   Reply With Quote
Old 07-30-2013, 06:58 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Those flues are rusted out and need to be completely replaced.
Pictures of the shingles in question will be needed to answer your other question.
tinner666 is offline   Reply With Quote
Old 07-30-2013, 07:20 PM   #3
Rewards Points: 12
you can see the track in the double layer in the picture with the flue
Old 07-30-2013, 08:40 PM   #4
Pro Slate Roofer
tinner666's Avatar
Where are the close-ups?
Old 07-30-2013, 08:41 PM   #5
Pro Slate Roofer
tinner666's Avatar
It's probably not too big a deal since the lifetime 50 year shingles should be good for 20years or even more.
The Following User Says Thank You to tinner666 For This Useful Post:
OldNBroken (08-04-2013)
Old 07-30-2013, 09:44 PM   #6
Rewards Points: 628
Those look like Renaissance to me, 3-tabs with some laminate portions on the tabs. Complete junk, oldest one i've torn off was ~14 years old. Pain to tear off too, just crumble to pieces. Closeups would help.
PatChap is offline   Reply With Quote
Old 07-31-2013, 07:08 AM   #7
Rewards Points: 13,220
What's that 3/8 copper line running up the side of those vents for?
I can see what looks like the ocean in the back ground.
Galvanized never should have been used that close to salt water!!
I'd be the org. builder did that to save money.
There's been several shingle company's that have had failures like that but you would need to know and prove yours was one of them.
Then all there going to give you is a pro rated amount toward the shingles not the labor.
I know if I had of been the company hired to redo those shingles I would have refused to do the job until all those vents where replaced.
There's a 100% chance there going to leak like that.
To me it looks like someone installed new pipe inside of the old rusted out pipe. Which would have be just plan stupid to do.
repairing cracks on a flat roof j_midcentury Roofing/Siding 22 03-16-2013 11:09 AM
Double wide roof construction / ventilation issue cgrfish Building & Construction 5 05-30-2012 11:21 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
replacement of shingle roof bernicel Roofing/Siding 14 09-08-2011 04:51 PM
Stain on Asphalt Shingle Roof stevedunn Roofing/Siding 2 10-22-2006 12:54 PM
